Under Bonnet Temperatures Causing Heat Soak
majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm Porsche OEM is also AN12 i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
Have a read of this: https://www.energy.nsw.gov.au/households/rebates-grants-and-schemes/household-energy-saving-upgrades/connect-your-battery-virtual Just one thing, your battery setup also must be supported by the retailer, at the moment for Fox Ess, only Amber supports it however that should expand with time. -
I've never heard of this before, how does it work?
