Sau:nsw - Monthly Meet February - Sunday Morning Cruise & Breakfast
The man of the hour...
Bald Hill Lookout
Heading south via the Sea Cliff Bridge
Arriving at Austi.
More 22B Love...
At the Austi Beach Cafe!
Refuelling the N1.
Mmmm big brekky.
Heading back home.
Raj and Kosta.
  • Like 8
Awesome day guys.
Glad so many people came along.
While many of us got wet I am sure everyone will enjoy washing the car afterwards.
Was also happy to see a diverse range of cars show up as well.
Hopefully will see more of the Subaru's and Mazda's!
Hats of to Raj for putting on another fantastic meet!
Already see so many good snaps (and some of my car as well, thanks guys!) and looking forward to more :)
  • Like 1
Here are some from me, it was a fantastic day! Thanks Raj for organising this, I can't wait until the next one.
I have put up a review on the day at https://www.facebook.com/33spec
So watch that page and also https://www.facebook.com/saunsw and over the next coming weeks I'll put up more photos.
  • Like 6
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
