2. run a tank of 98 every now and then to clean out the fuel system and avoid gummy buildup in your fuel system
How often do you guys fill up a tank of 98 to clean it?
United have very rapidly raised their prices, I have been considering getting my car retuned back onto 98 so I can get some kms per tank again since I'm not seeing prices as low as they used to be at the pump, it's a joke how much they've raised it.
its not really united, its now ethanole is trading on the same market as oil so market price is set along side oil price so varys as much when it shouldnt as its an entirly different economy
http://www.agmrc.org/renewable_energy/ethanol/ethanol-gasoline-crude-oil-and-corn-prices-are-the-relationships-changing/
This sort of explains it, basically instead of being set separately to oil prices all together as it should be the bulk ethanol prices actually is dependent on crude oil prices.
Making it not as cheap as it should be. Can't find the original article I read saying it's now being set the same way the parity pricing agreement with oil works.
From my understanding of ethanol, I wouldn't bother with a tank of 98 to "stop it gumming" as Ethanol is a solvent, which means it will actually clean out the gummy build up, as well as help clear up carbon build ups etc.
No point whining about it, I heard every excuse for not running e85 in Sydney over the years, it's too far away to fill up, Caltex e85 isn't consistent, not enough servo's to run e85 daily...
If more e85 was being sold they would have put more pumps in, end of story. I used to drive 22k's each way to fill up, in the snow with bare feet.
  • Like 1
They need to open a united servo with e85 in Sutherland shire
Doubt they will until Caltex pull their Eflex from kirrawee. So easy for everyone to fill up there on their way to the nasho
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
