Damned Carbonetics twin plate clutch just went, stripped both clutch plates of their splines. Not bad after only 5000k's. Can't say I have ever seen that before.
Anyway, box dropped today, clutch plates replaced and should be back on the road tomorrow morning, just in time to pull it all apart again and do the coilovers. The things we do to get to the track... :P
What the hell were you doing to the poor clutch to cause that, lol?
We still have plenty of spots open for the day, so if you are on the fence, get off it, as the long range forecast is for 0% chance of rain.
Here is a little inspirational video from 2012 with Cam Mcconville doing a track walk.
  • Like 2
Just a couple of questions
Firstly, I have filled out my CAMS Level 2 application, if I bring this on Saturday will I still be allowed on the track even though it hasn't officially been processed?
Also, my fire extinguisher is currently located by the floor of the passenger side rear seat, would this be acceptable?
How is it mounted? Securely with High Tensile Bolts and a Metal bracket/clasp or is it Tek screwed into the floor?
Can you reach it from your drivers seat while your seatbelt or harness is on and done up tight?
When entering, you selected to pay for CAMS as well? If so, bring the forms along on the day and we'll sign off on it :)
That position in the past has bedn generally acceptible. Though personally I'd like it closer.
Bring your cams paperwork and we, will sort you out.
It's fixed quite firmly with a high tensile screw to the seat mount.
Can definitely reach it while my seat belt is on.
Thanks for the quick feedback.
The notion of being able to reach the fire extinguisher whilst your harness is tightened is rubbish. When I'm strapped tight in my harness, I can barely turn my torso, let alone reach down to the floor pan to grab my fire extinguisher at my feet. Yet scrutineers have never said it's a problem in any event I've attended.
The only place I've seen these 'requirements' is in supplementary regulations for some events which are essentially "made up" by the club running the event. There is no such requirement stipulated in the CAMS manual.
http://docs.cams.com.au/Manual/GeneralRequirements/GQ09-Schedule-H-2015-1.pdf
  • Like 2
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
