still want to fit Japanese branded springs? You do don't you, go on, fit them please
what kills me is your blanket statement that japanese springs don't work.
so there is nobody out there with japanese branded valve springs with success lol you're kidding yourself aren't you
Edited by mr skidz
Well joeys spring broke in his engine and destroyed it.
what was the cause of the spring breaking was it installed correctly wouldn't be the first time a spring has broken and I'm sure there are many many circumstances where non japanese branded valve springs have let go just saying Edited by mr skidz
the only way to make them even semi work is to not cut the valve seats, but then the valves leak and defeats the purpose of rebuilding the head in the first place
95% of Japanese part are bolt in parts with factory specifications and once the factory specs are gone they no longer work
Paul had half a Japanese catalogue in his car and it just cracked 400kw, once he took out half the Japanese stuff and went with Australian made stuff he is now doing 475atw with smaller turbos, why? Cause there are no restrictions anymore and everything works properly
Car ran fine for 10 thou ks, I would have assumed that if it was incorrect installation it would have failed before then
Springs are supposed to have a installed seat pressure.
Has anyone checked the Jap brands at seat VS the others at seat?
Most people simply fit them without looking/thinking twice.
You supposed to know your free length which varies when reseating valves then check it before fitting to each valve individually, its part of blue printing the head.
Dont forget to check for coil bind depending on the lift and reinstalled height.
To break a spring may point to a scratch on one leading to a fatigue crack or over rev or a softened spring.
Now that leads me to question if the Jap springs are good when new but may be softening with repeated heat cycles.....food for thought.....
Hey guys.
Reading through this thread had made me wonder. Couple of months ago i dyno my car and it wouldn't make any more power above 17 psi. I thought i hit a massive restriction. But now i'm thinking if it's valve float.
At 16 psi it made this.
And at 17 psi it made this. Is this valve float?
Thanks in advance.
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
