Good notes Adam!
Definitely one of the biggest themes of the day was how the driveline is designed with shock absorbing capability, and changing this with stiffer components can lead to damage if the whole system isn't appropriately matched.
Yeah i reckon its something like this below - area under the curve is the same, but peak load/force is much lower with a soft (sprung) clutch. Engineering 101.
  • Like 1
Cheers guys for another great tech arvo.
Thanks to Award, Terry and Trish :)
Learnt some new things and got in some laughs as well.
Thanks Adam for the notes as well!
Will be looking forward to the next one :)
Was a damn shame I missed this, with both sleeping in and my calendar reminder not set properly I got the reminder 10 min's before the event :(
"Solid mounting of diff cradles also increases rigidity in a way that's detrimental (for the gearbox? or drive train more generally?), so make especially sure you use a sprung center clutch if you have a solidly mounted diff cradle."
This is good to know as I've just fitted a diff craddle and will be putting in the g'box brace in soon too, guess with the brass button clutch this is going to destroy my gearbox prematurely. :) JOY hahaa
oh, and lol.. not sure how many people found out in the day, but it turns out Terry and Trish live 2 doors down from me. It didn't click until we went outside for the ridiculously big spread they put on and i saw their car.
all in all, i think i learnt more from this tech session than any of the others.... thanks to all involved in organizing and putting the day on.
shift sedately and you will be fine, so no time attack shifts for you just yet!
I'm sure you'll find it's not so much how you shift the box as it is how you reengage the clutch that destroys boxes, this will apply to both going up AND down gears, should be done just like a motorbike, find friction point then release clutch not find floor then release clutch
  • Like 1
The other bit I got out of the day (more informative than anything) is that the only major difference between the series 3 BCNR33 boxes and other 32/33 boxes is that the syncros are "pad-type" rather than held in by circlips and also have a stronger (bigger) 5th gear synchro making them the design of choice if you have the option.
He also recommended that cleaning the gearbox can be done by running ATF in it for a while. Could be useful for those wanting to move away from smurfsblood which is nearly impossible to remove.
It was also interesting that Terry mentioned there is not a major difference in the various LSDs out there however for big power/time attack cars he did seem to recommend the Cusco up front. Seems he can also modify the standard ones making it potentially a cheaper option.
brass button clutch what friction point ?? HAHA
Yeah i think we was saying that like gearboxes, which are pretty much all the same in how they work, the factory, Nismo, Cusco etc LSDs are also pretty much the same. He can setup the rear to be tighter, however, since the after market ones are larger/beefier they will last longer.
I destroyed 5 brass buttons in 2 years due to the torque and everyone of them had a friction point
The distance between off and on was very very small though
no worries I have no torque HAHA
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
