Have you seen the size of the rods? One of the reasons the rods are almost bullet proof is that fact the stroke is so short. The pistons are also really short and stumpy. The leverage needed to bend them would be rediculous (Never said is impossible) Im not using stock rods cos im cheap. Im using them to prove a point.
Pistons where $300 barely used with rods lol im building the engine myself.
these 2 post contradict each other
How so? Lol im using stock rods with pistons? Im stating stock rods or any rb26 rod will be harder to bend? Like i said lol
Im not putting chinese h beams in my engine. Ill stick what nissan made.
Anyways this post has turned to what i should do. As far as im concerned its not your build its mine. Ill do whatever im gunna do. Lets keep it on topic. Only one person since has actual evidence of rods out performing, rest are just irrelevant "comments"
I would never use stock rods in any serious build without spending hours and hours on them; on the linisher, on the scales, on the x-ray machine, etc etc. And if there were very good aftermarket rods available at a reasonable price then I would have to value my time at nearly zero to justify doing all that instead of just buying the good aftermarket ones.
Just sayin'.
Edited by GTSBoy
Years ago (back in the 70's and early 80's) when aftermarket rods were really expensive, we would spends days preping stock rods to be a "little" better than the stock items.
Today looking back at it, its pointless to try this, the labor cost of shot peeing, resizing and balancing the rods is much higher today compared to what labor costs were back then VS new aftermarket rod costs of today, its simply no longer economical to mod stock rods.
I simply wouldnt throw out stockers and put some aftermarket ones in, and then sleep at night knowing i had something even stronger than the modded stockies.
Just sayin'.
yeah....but he is proving a point....not sure what that point is exactly....but im sure it is pertinent.
but hey...300 dollar used pistons.....what could go wrong...
37 comments. Only one thats worth taking serious. Rest is "advice" from people who have never ACTUALLY done it. Infact most of you dont even own a rb26, or even built a engine.
"Adam's R34 GTR now makes 557kw@31psi with a small shot of nos, and 509kw@29psi without nos.
It has a stock RB26 with cams, gears, springs, studs all drop in, HKS T51R turbo, custom fuel system with triple 044 and under car surge tank all manufactured in house, nismo cooler, os triple plate clutch, intercooler, all controlled by a Haltech Platinum Pro and I/O box setup.
Adam wants to see what the stock bottom end can take. Looking forward to power cruise tomorrow."
-Just Engine Management
Keep your eyes peeled ladies.
