Does it guzzle fuel?
only when the motor starts :)
You can see it splashing out the back when you press it,coughing and farting but not as bad as I thought it would.
I still think it was thirstier when it was a 26 , I had to push it harder , now I get better results at lower revs, if that makes sense :/
What is so good with it as a 3.2 is how linear it is from the start, it goes hard but feels like you have the control on the twisty bits. I think the car works great as an all rounder , but i am biased :blush:
cant believe how (if its actually) rich this car is running
well , the plugs get black dry fouled, blows soot out the back, back fires and farts coming down step hills, goes tits up at higher revs and smells rich, could be rich, how rich, wish I was this rich :)
why is that, it is good for over 700HP and it is nowhere near that ???
Small turbine housing, restrictive exhaust with a big pump (engine)... engine is choking.
3.5" will do it... a 2" will 'do it' but why would you want to? Biggest exhaust you can then try and make it quiet with highest flowing mufflers you can if that is an issue.
Surely 3.5" all the way with a free flowing Cat and Muffler should be enough for my goals, I am not chasing every last KW out of the build. I wanted a strong motor that will last as a DD and let me play when I want :)
Really, what a cock of a size, 3.5" should still be good enough
Gotta be better then 3" :(
where down pipe clamps onto the back of the turbo it is 3" outside i diameter , this goes down to the 3" Cat, then it comes out and steps up to 3.5" exhaust
Pic
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
