I have left the banter in here as it has been generally acceptable, if not borderline. But consider this as a first and final warning, any further personal slander/affray (especially bringing race into it) and I will start editing heavily and handing out bans.
Also Paul, I have removed your car list from your profile - it makes every post you make ridiculously large when viewing the forums.
Can you move it to my Signature Line below my track times then if you still can somehow?
As it was wrote out specifically that I won't get back again :(
There is definitely a turbocharged CVT getting about locally, and it's still running fine afaik. The box isn't weak, just misunderstood.
I thought you had the RE4 for a minute, but yes, if you can drop in with it I could check out the diagnostics Nissan use to service the CVT. I don't specialise in transmissions, but I have shift kitted many Nissan auto boxes.
But would that be the KTF-1 CVT Diagnostics? Or the old NS-2 CVT Diagnostics???
Or it doesn't matter when reading the CVT?
Sorry Paul it is gone. And to be honest, and no offence meant, but no-one cares what else you drive :P - also, your sig is already too long - I almost edited out your silly "TBA" lines as well.
  • Like 1
KTF-1 and NS-2 are fluids.. also NS-2 is newer. NS-1 was used on the early pushbelt CVTs, NS-2 on the mid to late 00s, and NS-3 is used on the current range.
I would expect if the consult3 can read and communicate with the TCU, then it will work regardless of what type of fluid the CVT runs.
  • Like 1
Not sure what your getting at. If you look at where the lines are routed they come right out the front of the car past the radiator and behind the bumper into some bulbus thing which is probably either a filter or a thermostat or something... I forget and I cant look into it further as I sold my car recently.
Just saying you can't block the fluid flow from the cooler like you can with engine coolant. you would need to bypass the cooler to still allow the fluid to flow back to the pan, otherwise you would create an enormous amount of fluid backpressure in the transmission
  • Like 1
Yep.
If you look at how trans cooler thermostats work they don't block the flow, they just allow it to bypass the cooler. Its exactly the same as an engine oil cooler thermostat. They don't block the flow of engine oil. That would be silly
  • Like 1
As said it just does not work like that if you use the correct parts which I listed. If you do your own research you will understand this its pretty simple stuff really.
Regarding the turbo CVT. Nissan tested this cvt behind their v8 engines of hte era (1990's) and obviously the 3.0 turbo. I would suggest this CVT can take about 350 or so hp but the thing is gearboxes are usually rated in torque output. Once you turbo a 3.5 you are playing with fire with this CVT behind it. The heat generated by the extra torque will kill it sooner or later.
Again I still say anybody that turbo's one of these is nuts. I dont care what anyone else thinks.
Edited by austingtir
  • Like 1
I would tend to agree.. considering Nissan use a normal pushbelt CVT behind the same 3.5L engine in the Maxima/Murano (sure, slightly detuned). and then they specifically say the toroidal CVT was built to handle high torque, I would say it could handle quite a bit more than the maxima/murano CVT before 'throwing in the towel'.
That said, if you exceed its limits, it will get messy fast! and there is no option to 'rebuild' it to handle more torque like you can with standard auto transmissions.
  • Like 1
The early CVT's had only one drum in the fluid, which meant the higher drum wore quickly if the fluid was old or the fluid level was low. The newer CVT's, both drums are in the fluid, which makes them much more reliable. This is essentially why the early CVT's got a bad name.
I spoke to my Nissan mech buddy last night, there is definitely a fluid timer which changes certain functions as the fluid deteriorates. This can be reset from the Consult3 as I thought.
  • Like 3
That's it Scotty. Pretty sure it states that in the workshop manual - which I can't find now :(
  • Like 1
Interesting.. you don't happen to know what it changes?
Anyone here in NQ with a Consult3 clone? Or know of any C3 clones that can do this and not cost $1k? I flushed the fluid on my wife's J31 CVT a couple of months ago, and if this is correct, I probably should have the fluid deteoriation counter reset!
  • Like 1
Why on earth would you want to track/push hard on a GT-8 in the first place?
Earlier CVTs are known to have issues when thrashed hard.
If you want to race/track/drag a car, at least get a 5sp auto or 6sp manual.
V35s are named with GT for a reason - grand touring is different without the "R"! Of course you can have a heavy foot and have fun around the corners or keeping up with the traffic, but I would never track a GT-8.
  • Like 2
And that's the way I am keeping it Francis.
Mainly Highway driving & the occassional 2-3 laps to set my best track times.
I seen what happened when you do 6-7 laps at a time!!! Wasn't good for the health of the box at all :(
Is there a service kit available for the Extroid anyway? Ie Gasket, Filter & O-Ring altogether in a kit???
I went to CVT.co.nz & not one part is for the Extroid!!!
Yeah service kit is is sump gasket, o-ring and oil. If there is oil weeping from the side of the box then you'll need copper washers for the banjo bolts.
Check my for sale thread a few pages back for part numbers
  • 3 weeks later...
But would the PV35 have a fluid deterioration sensor?
Has anyone got a GT-8 & confirm they had theirs reset after the flush???
As the way I am reading this page, is that its mainly in the J31 (Pushbelt) CVT models that you can have it reset?!
+1 to MV. theyre currently sending me a shift kit for the RE4.
cvt.co.nz do sell gear too, but they werent interested in my business once i said i wasnt buying oil from them.
31526-5P009 (O-Ring)31397-5P000 (Gasket) (someone will need to confirm Y34 is same as V35. it should be same, but Y34 is "6 speed" CVT so small chance is different sump)
Exactly the same thing that is happening with me!
CVT.CO.NZ - don't want to help you out unless you're buying oil from them for the Extroid!!! :( How lame...
You still have the gasket & o-ring for the GT-8 CVT Lee-Ham?
yes i do. i think ive got them for sale for $45 for both + postage.
  • Like 1
Is there a Filter inside the CVT that can be changed as well?
Like Auto's have or just the O-ring & that's it!?
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
