Hey guys I got a r33 GTS25T few months ago, i'm loving it but the guy I bought it off said it had a nismo 1.5 way but I have no idea how to find out, i've done a few searchs and basically you cant tell from looking you have to take a cover off. Anyway my question is how do I stop the shuterring at low speed turns. This car is my daily and will always be, it just gets quite annoying going through car parks lol. So can this be stopped through a oil change or adjusting backlash (i have no idea what this is, just been reading other threads) or do i have to deal with it? Thanks.
https://www.sau.com.au/forums/topic/455474-r33-nismo-15-way/
  • 4 weeks later...
Hopefully it isn't a shimmed stock diff, they can shudder badly too if they shimmed it too tight.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
