Long story short bought my car back in Mid 2009 as a P Plater, took me a month to find a ivory pearl white one I wanted.
It was stock as a rock and I was full into the stanced and offset style back then. After a few weeks I found some wheels I liked and needed to buy.
Evolution Intensive Hunks in Chrome with huge dish
Japanese made
19x9.5" +17 fronts 245/35 tyres
19x11" +10 rears 275/30 tyres
Whacked them on the car and boy it was Mexican as holy moly.
Drove around like that for a few weeks but the ride height was hideous, looked like I had a 2" lift kit in the sucker so that needed to change.
Came across some 40 mm lowered eibach springs, bought them, installed them and the ride height was looking good. Wasn't tucking tyre but way better then before nor was it as Mexican but still had a good amount of poke.
I Got bored with the performance of the car so the engine needed attention.
few months down the track i did a few bolt on mods including intake, cat back exhaust , Plenum Spacer and SAFC II.
Forgot to mention when i bought the car i went to the track and managed a 14.7 in stock form, with the mods and the big wheels i managed a 14.0
i was happy with that for a P Plater back then.
Performance was done and now back to the look of the car, the height needed to come down more, i found a cheap set of d2 coilovers and i Didn't have any intentions on tracking or racing the car, just needed it to slam the car. Suited my needs perfectly.
Rocked up a week later installed them and put it to the lowest setting as possible in the rears and matched it for the fronts.
Viola, my stance game was looking strong, it was looking awesome.
So i've had the car about a year at that point of time, within the next year i went through about 3 rims or so.
https://www.sau.com.au/forums/topic/455613-bees-lsv35-skyline/
In mid to late 2011 i blew my motor, it was a sad day to say the least.
I got the car back home and it sat in the garage for about a year before i decided what i wanted to do with it.
i started to pull the motor out and checked the sump, as i thought, i spun bearings after looking at my sump.
off to my mates workshop, NextUp Performance and started planning my build out.
This was the start of something great, which was around 2012.
My new motor and box
A L98 6.0L motor out of a 2008 VE SS I purchased off my mate and a TH400 3 speed transbraked auto gearbox that i got built.
The 6.0L had a standard bottom end but it has valve springs/pushrods and lifters and a cam upgrade that previously made 620rwhp through a supercharger.
My plan was orginally to just keep it N/A and run a nice shot up of nitrous up its clacker.
but after a few months down the track i spoke to mates and i decided to go down the turbo route as this was the future plan after it was N/A.
gathering more parts for the next year or so which included
TCE Torque converter
Shifter
Flex Plate
Engine Accessories
Fuel system ( 3L surge tank, 4x 044 fuel pumps, 2 carter lift pumps, 2 fuel filters)
Haltech PS2000 ( which i've changed to a ELITE now)
Haltech Dash
Precision CEA 7675 turbo
Turbosmart 50mm pro gate
Holley Fuel rails
Drag wing
bought these parts slowly when i could afford it.
i then decided to change to a bigger cam from the orignal 233/233 that it had to a nice and lumpy 238/242 with the same lobe seperation but with abit more lift. I also did aftermarket head gaskets and ARP Headbolts as i did not want to lift the head with boost pressures as LS's are known to do.
That was sorted , so in the past year, i've slowly started to put the push on this build.
first off the engine had to be custom mounted, Cross memeber was notched and plated to suit the sump we modified as i wanted the motor sitting as low and as far back as possible.
Motor got mounted and the tranny,
Fabulous Fabrication did an amazing job on this, Next the big job was to get turbo manifolds done. Few days later working on and off on my car they were completed, i couldn't of been happier. Everything had to be taken into account from fitment to space for other things like alternator, piping, exhaust etc etc which was a headache to be honest
Motor was back out so i could paint it black, i wanted it to be stealth so everything was going black.
At this point i was still buying parts for the motor, like intake manifold, i ended up going with a holley single plane manifold as i heard and reasearched they are good for forced induction applications. With that i had to get a elbow to suit so a 6061 aluminum elbow was the choice to mate up to the standard fly by wire throttle body.
Bought some front wheels for it too, looked sooo goood.
Weld racing V series Front runner 17x4.5"
Motor went back in, measured up tailshaft length to get made, turn around time was about a week.
Tailshaft arrived, that got mounted.
Prior to that, a few months ago I had a good chat to Fabulous Fabrications and the Boy at Next Up Performance which will be tuning the car after.
We decided that the turbo manifold weren't gonna work for the size of radiator we wanted to run, wasn't going to be big enough.
This was actually good thing, as i didnt really have that much room for a big intercooler so i bought a 450x300x110 intercooler.
Few weeks ago Fabulous Fabrication moved the turbo further forward thus modifying the manifolds again leaving us more room to fit a larger sized radiator, measured up the room we have and a custom PWR radiator 500x500x50 is getting made as we speak.
Fabulous Fabrication also mount the Intercooler and did the hot side intercooler piping with a Plazaclamp, it looked wicked cool.
He also modified the intake side from a 3" inlet to a 4" inlet.
  • Like 4
gee that escalated. what are/were your plans for the build?
surely diagnosing what caused the first motor to die and then build up a mean VQ would have been cheaper/easier? (though i can understand people being over V6's)
VQ35's are known to use oil, so low oils caused spun bearings, parlty my fault as I should've checked oils.
To completely build a VQ and purchase a turbo kit and supporting mods, ecu/fuel system etc etc, from the states would work out roughly the same in price.
Intentions of the build is just a street car with the intentions of drag racing it.
whack some chevy badges on it to really rustle some people's jimmies! :P
Love it mate, can't wait to see more progress.
May I ask the reasoning behind a turbo kit over the more commonly done supercharger kit for LS?
That did cross my mind a few times lol :L
personal preference pretty much, also I find the power delivery of a turbo much more fun and aggressive than a supercharger.
doooooo eeeeet
Fair enough re: the turbo. Hope your set-up is everything you want it to be :) congrats on doing something different. I like different
Definately Big Transformation over the years.
Brake upgradea week ago thanks to PN-Mad
r32 GTR 4pot calipers, Drilled rotors and pads 296x32mm VS standard piston 296x26mm
post-33487-0-35324000-1429272210_thumb.jpg post-33487-0-35155500-1429272291_thumb.jpg
Working away doesn't give me time to work on the car so My good mate did my fuel system tonight, all plumbed up.
  • Like 1
  • 1 month later...
Been slack with the posts, here's and update.
Car has been running and driving for over a month now, really happy with the outcome and can't thank my boys enough at Next Up Performance.
My car makes a solid 525rwhp on 10psi with United E85
The night before QLD May 2015 Powerplay ready for the dyno.
Car on the dyno awaiting tune.
Rolls off dyno what a better way to celebrate, Shed Skids!!
https://instagram.com/p/2apzngkAJS/
  • Like 2
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must me missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
