Long story short bought my car back in Mid 2009 as a P Plater, took me a month to find a ivory pearl white one I wanted.
It was stock as a rock and I was full into the stanced and offset style back then. After a few weeks I found some wheels I liked and needed to buy.
Evolution Intensive Hunks in Chrome with huge dish
Japanese made
19x9.5" +17 fronts 245/35 tyres
19x11" +10 rears 275/30 tyres
Whacked them on the car and boy it was Mexican as holy moly.
Drove around like that for a few weeks but the ride height was hideous, looked like I had a 2" lift kit in the sucker so that needed to change.
Came across some 40 mm lowered eibach springs, bought them, installed them and the ride height was looking good. Wasn't tucking tyre but way better then before nor was it as Mexican but still had a good amount of poke.
I Got bored with the performance of the car so the engine needed attention.
few months down the track i did a few bolt on mods including intake, cat back exhaust , Plenum Spacer and SAFC II.
Forgot to mention when i bought the car i went to the track and managed a 14.7 in stock form, with the mods and the big wheels i managed a 14.0
i was happy with that for a P Plater back then.
Performance was done and now back to the look of the car, the height needed to come down more, i found a cheap set of d2 coilovers and i Didn't have any intentions on tracking or racing the car, just needed it to slam the car. Suited my needs perfectly.
Rocked up a week later installed them and put it to the lowest setting as possible in the rears and matched it for the fronts.
Viola, my stance game was looking strong, it was looking awesome.
So i've had the car about a year at that point of time, within the next year i went through about 3 rims or so.
https://www.sau.com.au/forums/topic/455613-bees-lsv35-skyline/
In mid to late 2011 i blew my motor, it was a sad day to say the least.
I got the car back home and it sat in the garage for about a year before i decided what i wanted to do with it.
i started to pull the motor out and checked the sump, as i thought, i spun bearings after looking at my sump.
off to my mates workshop, NextUp Performance and started planning my build out.
This was the start of something great, which was around 2012.
My new motor and box
A L98 6.0L motor out of a 2008 VE SS I purchased off my mate and a TH400 3 speed transbraked auto gearbox that i got built.
The 6.0L had a standard bottom end but it has valve springs/pushrods and lifters and a cam upgrade that previously made 620rwhp through a supercharger.
My plan was orginally to just keep it N/A and run a nice shot up of nitrous up its clacker.
but after a few months down the track i spoke to mates and i decided to go down the turbo route as this was the future plan after it was N/A.
gathering more parts for the next year or so which included
TCE Torque converter
Shifter
Flex Plate
Engine Accessories
Fuel system ( 3L surge tank, 4x 044 fuel pumps, 2 carter lift pumps, 2 fuel filters)
Haltech PS2000 ( which i've changed to a ELITE now)
Haltech Dash
Precision CEA 7675 turbo
Turbosmart 50mm pro gate
Holley Fuel rails
Drag wing
bought these parts slowly when i could afford it.
i then decided to change to a bigger cam from the orignal 233/233 that it had to a nice and lumpy 238/242 with the same lobe seperation but with abit more lift. I also did aftermarket head gaskets and ARP Headbolts as i did not want to lift the head with boost pressures as LS's are known to do.
That was sorted , so in the past year, i've slowly started to put the push on this build.
first off the engine had to be custom mounted, Cross memeber was notched and plated to suit the sump we modified as i wanted the motor sitting as low and as far back as possible.
Motor got mounted and the tranny,
Fabulous Fabrication did an amazing job on this, Next the big job was to get turbo manifolds done. Few days later working on and off on my car they were completed, i couldn't of been happier. Everything had to be taken into account from fitment to space for other things like alternator, piping, exhaust etc etc which was a headache to be honest
Motor was back out so i could paint it black, i wanted it to be stealth so everything was going black.
At this point i was still buying parts for the motor, like intake manifold, i ended up going with a holley single plane manifold as i heard and reasearched they are good for forced induction applications. With that i had to get a elbow to suit so a 6061 aluminum elbow was the choice to mate up to the standard fly by wire throttle body.
Bought some front wheels for it too, looked sooo goood.
Weld racing V series Front runner 17x4.5"
Motor went back in, measured up tailshaft length to get made, turn around time was about a week.
Tailshaft arrived, that got mounted.
Prior to that, a few months ago I had a good chat to Fabulous Fabrications and the Boy at Next Up Performance which will be tuning the car after.
We decided that the turbo manifold weren't gonna work for the size of radiator we wanted to run, wasn't going to be big enough.
This was actually good thing, as i didnt really have that much room for a big intercooler so i bought a 450x300x110 intercooler.
Few weeks ago Fabulous Fabrication moved the turbo further forward thus modifying the manifolds again leaving us more room to fit a larger sized radiator, measured up the room we have and a custom PWR radiator 500x500x50 is getting made as we speak.
Fabulous Fabrication also mount the Intercooler and did the hot side intercooler piping with a Plazaclamp, it looked wicked cool.
He also modified the intake side from a 3" inlet to a 4" inlet.
  • Like 4
gee that escalated. what are/were your plans for the build?
surely diagnosing what caused the first motor to die and then build up a mean VQ would have been cheaper/easier? (though i can understand people being over V6's)
VQ35's are known to use oil, so low oils caused spun bearings, parlty my fault as I should've checked oils.
To completely build a VQ and purchase a turbo kit and supporting mods, ecu/fuel system etc etc, from the states would work out roughly the same in price.
Intentions of the build is just a street car with the intentions of drag racing it.
whack some chevy badges on it to really rustle some people's jimmies! :P
Love it mate, can't wait to see more progress.
May I ask the reasoning behind a turbo kit over the more commonly done supercharger kit for LS?
That did cross my mind a few times lol :L
personal preference pretty much, also I find the power delivery of a turbo much more fun and aggressive than a supercharger.
doooooo eeeeet
Fair enough re: the turbo. Hope your set-up is everything you want it to be :) congrats on doing something different. I like different
Definately Big Transformation over the years.
Brake upgradea week ago thanks to PN-Mad
r32 GTR 4pot calipers, Drilled rotors and pads 296x32mm VS standard piston 296x26mm
post-33487-0-35324000-1429272210_thumb.jpg post-33487-0-35155500-1429272291_thumb.jpg
Working away doesn't give me time to work on the car so My good mate did my fuel system tonight, all plumbed up.
  • Like 1
  • 1 month later...
Been slack with the posts, here's and update.
Car has been running and driving for over a month now, really happy with the outcome and can't thank my boys enough at Next Up Performance.
My car makes a solid 525rwhp on 10psi with United E85
The night before QLD May 2015 Powerplay ready for the dyno.
Car on the dyno awaiting tune.
Rolls off dyno what a better way to celebrate, Shed Skids!!
https://instagram.com/p/2apzngkAJS/
  • Like 2
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
