Hey guys,
New to the forum and new to the skyline world. I bought a 33 two weeks ago. It has a full 3" exhaust with cat and hotdog muffler and originally had a cannon. I got a hold of a set of 3" stainless straight pipes and put them on mainly because i dont like the look of cannons but since have noticed a power loss top end. It just feels a lot slower, even changed the way it hits limiter.
So I'll probably put the cannon back on to gain the top end performance back, but I don't really want to. Is there anything else I can run thats not a cannon or straight pipes and will do what I want?
Thanks in advance.
I assume by "straight pipe" that you mean you replaced the rear muffler with a section with no muffler. Or possibly that you replaced the whole lot including the hotdog, meaning that you have nothing but pipe behind your cat. If either of those cases are true, then I would expect;
  • It's horribly loud,
  • It probably sounds like arse raping a donkey,
  • It shouldn't do ANYTHING to make your car make less power.
So either it just feels slow because it sounds so bad, or just possibly, and I mean JUST, it has increased air flow through the engine sufficiently that the shitful R33 ECU has decided to put you into R&R territory and is calling a halt to the fun. In which case, it's not about the exhaust, it's about management.
Its just twin stainless pipes from the diff back, the hot dog is before the diff. It sounds good up until 4000rpm then has horrible stainless Eco. And was thinking it'd be the pipes cause who ever made them was pretty dodgie, like where the Y pipe is they've slipped 3" pipe over it and left the end of the Y pipe that should have been trimmed flush on the inside of the 3" pipe there, if you know what I mean, so could be hitting that and restricting it or f**king up flow?
As stated previously, any power difference is usually placebo effect. Tuck a quality 3" muffler up in the standard cavity and put a dump pipe on it. Having idiotic cannons hanging down on stupid angles is a good way to get a cops attention.
One suggestion, focus on keeping it legal or stealth as possible unless you want to get pulled over or defected regularly. Something custom is usually a lot better and works out well depending on the purpose of the car.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
