http://www.kudosmotorsports.com/catalog/genuine-nissan-pitwork-heater-hose-kit-14piece-nissan-skyline-r32-gtst-gts4-rb20det-p-1598.html
RB25 kit won't fit.
Use this kit from Kudos instead as it will have everything you need. Check it suits your model r32.
Other option is to use Nissan Fast and get the codes for each hose (14) and get them through Nissan which would probably be about the same amount and time consuming.
This took 5 minutes max to search and respond so don't know how it took you a week with no results.
Edited by breaker1845
RB25 kit won't fit.
"these are not the hoses I'm looking for"
The ones i'm talking about are underneath the intake manifold
Id say they would be included in the above mentioned kit
The hoses that connect the hard pipe to the block etc and all the little hoses (for coolant bleed and turbo coolant line) that are under the intake manifold?
They come in the kit
Edited by 89CAL
hey fellas.
been doing bout a weeks worth or research and no turn up.
I'm wondering if the cooling hoses underneath the intake manifold on the RB20 are the same sizes as the RB25, just looking at getting an RB25 kit if they fit.
Cheers.
just head down to enzed and grab a length of heater hose, and cut to suit
Edited by Dan_J
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
