Hi guys
i'm selling most of my spare car parts I have accumulated over the years due to new commitment.
BNR32
Front Strut Bar, manufacture unknown there is some scratches - $65
Front Strut Bar, manufacture Aiba, - $65
Front Strut Bar, Cusco, - $85
Rear Strut Bar , Cusco - $85
Floor Cross Bar, Do-Luck - $250
Genuine weather shield NEW two pairs - $350 each pair
Blitz twin core radiator in good condition, no leaks, comes with fan shroud and radiator cap $ 390
Tein Comfort Sport, 16 Stage damping, 5k and 4K spring Rate no leaks or Knocks in good condition - $1400
Ohlins Full Tap 20 stage adjustable coilover with hyper coiler springs, 9k and 7k spring rate, no knocks or leaks, very good condition - $2650
Trust Oil cooler kit in very good condition $350
HKS Oil Cooler Kit $400
Ikeya Formula adjustable camber Arm Rear, Near new condition $410
Nismo 600cc Injectors good condition $520
Greedy 4pcs intercooler pipe kit $370
ATS twin carbon plate clutch push type comes with flywheel, both clutch plates are at thickness of 3.9mm plenty of life left in them - $820
Nismo Front and Rear Sway bar set front sway bar 22.2mm rear is 27.2mm - $500
Cusco 7 point roll cage in good condition with everything you need for fitment, around the dash. - $700
Okuyama 6 point though dash Roll cage in good condition everything everything you need for fitment - $520
Stainless steel front pipe two 70mm to 80mm brand unknown, no leaks - $200
Nismo GT Pro LSD 1.5 way final gear ratio 37:9 in very good condition - $1000
R32 GTST GTS
Genuine Weather Shield New - $240
BCNR33
Genuine weather shield NEW - $350
Ohlins DFV coilovers, travelled 3000kms 9k and 8k spring rate 20stage adjustable near new condition $2700
HKS Hypermax 4 GT 30stage damping 8k and 7k spring rate in good condition, no leaks or knocks $1600
O2 sensor x2 $120
ECR33
Nismo G-attack s tune 4 stage damping, no leaks good condition $950
Tein Type RS circuit master coilover 16stage damping and rebound adjustment, good condition 10k and 9k spring rate $1750.
Ganador Exhuast 80mm to 90mm tail is 120mm. no leaks, good condition $ 550
BNR34
Nismo R tune Air duct, Brand new - $490
Tein Street Flex Coilovers 16stage damper adjustable 8k and 7k spring rate no leaks or knocks good condition - $1050
Kakimoto Cat back Regu06 80mm to 90mm and 110mm minor scratch marks but no leaks - $620
ER34
Twin core Radiator, 50mm core size no leaks and good condition - $ 190
Trust Oil Cooler kit good condition - $500
Other
Nismo Clear side indicator Brand New - $90
Nismo Carbon fiber inside Mirror cover Brand new R32 and R33 - $260
Can ship anywhere at buyers expense.
I will be uploading the photos shortly
Please do no hesitate to PM me
thank you
Hi Roy,
For my BNR32, I'd like to buy the...
* Nismo F&R sway bar set if HD links/bushes are top condition. Pics?
* Nismo c/f interior rear vision mirror cover
...please.
I can pick up from Mortdale. Ta
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
