Not ALL split dumps are the badguys everyone is making them out to be. Obviously their design is the big factor. I ran a split dump on my GTX3071R setup and never had a boost contol issue with a 1 bar actuator running 25psi of boost.
  • Like 1
^ Exactly. Teh genuine HKS split dump has a notch in it to allow no interference. It also has the gasket that completely separates exhaust/wastegate (for hks gt series turbos)
Then the china copy lots of people have dramas with with the divider for stock turbo, yuck.
Edited by R31 POWER
I'm hoping this doesn't turn into dump pipe wars , I just think that for the effort and expense involved making divided ones isn't worth it .
The flange plate absolutely has to match the housings inside profile meaning that if the dump side doesn't , function wasn't its primary objective - cost cutting was . Its obviously more time consuming to profile cut the inside of the plate than it is to run a hole saw through it .
I reckon 3.5" tube welded to a properly made GT30IW flange plate with a decent gusset isn't going to lack flow potential on a typical RB25 install . Plenty of exhausts are 3" and they can support good power if the whole system is made with good mufflers cats etc .
A .
I been there and done this long time ago, I paid $500 to have the IW modified and an XR6 flapper installed, still no change, then it was decided that the holes didn't line up and the flapper was hitting the flange and all sorts of backpressure... got an open mouth dump and all sorted...
Just get an external and don't stuff around with it, its a waste of time and money...
If you put the effort and expense in, and you match everything up properly, it is worth it. If you buy some ling long piece of crap for $200 and expect it to work just because it's split then you only have yourself to blame.
It's easy to f**k up a split dump, but it's hard to f**k up a bellmouth. Keep the law of averages on your side unless you have the time and expertise to make sure a split dump fits properly. I'm a huge bellmouth fan because I hear stories of obstructed wastegate travel ALL THE TIME.
I remember i had an issue like this long time ago with a halset turbo. It just kept over boosting even when i tied the gate open. Talk about lost. So one day i took the turbo off and noticed it was a t3 twin scroll. The gate only vented from one side. The othere side just kept boosting. So over boost hard. I noticed it only controlled boost over 22psi. So thats what i aimed for. I upgraded everything to handle more than 22 psi. She was good after that. Hope thats not your issue mate. Cheers
Edited by MJTru
UPDATE UPDATE UPDATE.!!!!!!!!!!!!!
So as i think i mention the travel of the flapper was stuff all yes. I manage to get a 10mm dump spacer. Which i had to port anyway because it had way to much meat on it, So I ported until it match perfect with gaskets and housing. Slapped it together and i can now flog 3rd and 4th and the boost not only does not move, it drops off at the top (only a little).
So the flapper was fouling on the dump, spaced it out so it doesnt hit and works like a charm. I must also add there is no divider in the spacer so gases can kinda swap and choose its outlet path (thought it would be a issue) but works fine,
Thanks for the dump pipe hit :)
As for going external wastegate. Yes Highly recommend, but it is a bit tight on a low mount setup (yes i know its been done before). If you can do the whole high mount, FFP ect. ect. go for it as many manifolds are made for high mount to suit external gate. All about budget a commitment
Edited by Jaydenk92
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
