the car is running perfectly (aside from the leak), but it's unregistered so I can't get it down to bunbury. I can nearly reach the hose with my fingers from the top of the engine, they're just not long enough.
That being said, I don't have the know-how to remove all of that stuff, and it sounds near impossible to do in my drive way.... hmm. Will most likely look into it tomorrow when the sun is up and come up with a plan.
If anyone is in the Forrestfield Area with the know-how and feel like helping, hit me up so can plan this better.
Was thinking of starting a thread like the music one "what are you listining to" but call it "what are you laughing at" not having facepage i miss out on some of these.
Tried the lulz thread?
  • Like 1
I'll upload two more photos in an attempt to show where it is, in one of the photos of can clearly see it gushing out coolant. It's at the rear of the motor, just behind the rocker cover underneath another pipe.
http://imgur.com/a/bTzuJ
Yeah, not many 4 door R33 GTST's out there with a manual transmission. Don't worry, I'll fix that problem eventually, right now I need to get this car registered.
Besides - Auto's win races ;)
Edited by Manne
  • Like 2
Manne, you'll be right. I had to do that same hose on a 300zx tuesday, You have 0 things to complain about
I'm not complaining, I value the educational experience.
any advice? approach from under the engine or above? I was reading somewhere that removing the starter motor gives you more access?
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
