Sideway action =)
Or just get fatter tyres
Fatter tyres can aquaplane (sp?) though!
Also how good is #justanotherdayinWA on Twitter!? It's providing the lulz this afternoon.
https://twitter.com/hashtag/justanotherdayinwa?f=tweets&vertical=news&src=tren
You have a gearbox business?
Australind automatics!!
Best repair place in the sou-west!!
But not limited to gearboxes only, Corey is da man.
Yeah what Trev said. Do a bit of everything but specialize in autos, manuals, diffs, and suspensions
