f**k, why do people call using using an unknown number and not leave a message. Like I can magically know who you are right. :domokun::domokun:
This annoys me.
Or when someone leaves a message and they just call back. "Who tried to call you?" "What was this in regards to?" "Errrr... I dunno, I didn't listen to my voicemail." ffs
Is it weird that, I am now more motivated than ever to finish my car?
I actually have a plan now visually and know exactly what I want to do.... It's just a shame that I can't do so for literal months because i'm a poor retail worker :(
  • Like 1
