[emoji28][emoji28][emoji28][emoji28][emoji28] were so excited! Can't wait! Trev , Corey & Dean Thank you so much for the tips and info :) keep em coming , still need few
More informations [emoji6]
  • Like 1
Morning all. Yay exciting Elle, you'll have a blast. Just make sure you don't go through singapore security with wheel nuts or engine mounts in your carry on :glare:
Morning everyone !
Hahahahahahaha nah [emoji28] I won't Corey [emoji48]
