3 hours ago, Hank Scorpio said:
Morning all!
That time of the year to renew my car insurance, why do all bills come at once?
I pay the V36 monthly and the R34 yearly. Don't think I can afford to pay it all at once
aw man, Skyline Cruise and my car is still at the bodyshop.... not sure if i'll have it back by then...but if I do... I might go, as a celebratory thing.
Déjavu Manne
Last time hoping it was registered in time
morning all, wow been so quiet without the SAU crew and waking up with less email notifications. Well that cruise is in the evening so provided I do get my car back today I will be going. As for body kit I got mine from URAS in Japan but 1st time went thru monster garage and 2nd time thru Nengun.
15 hours ago, pol1on1 said:
https://www.facebook.com/events/1704943473114154/?ti=cl
This Saturday skyline cruise only don't know if you guys know. Just throwing it out there :)
That's ok, I didn't want to be loved anyway... *sniffs*
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
