On 8/3/2016 at 9:39 PM, t_revz said:
Dale-head
How's things mate?
spiffing
If you call 65-70 hours a week in a truck spiffing
I am, however, getting to see a lot of this corner of the state.
Plus, dirt bike.
  • Like 1
I grew up down there, All my family is still there, but I got out.
Im "driving" a Silver R33 4door. Plenty of pics posted earlier in the thread.
Who'd have thought changing spark plugs in an RB25DET was such a pain.
Leave the centre cover off and it's only a 10 minute job to do them
