Aye!, My Car is fixed and running beautifully. Im about to take her out on a long-ish drive, see if she's ready for tonight.
Oh yeah, and @pol1on1  you seen this yet?
Very interesting I've seen 1st one of the the 3 but last one wont load other. but 2 are definitely a brain twister i like this :)
Great news that your car is running well again!.
Oh btw SAU has been playing up in last few days
A. Kicked me off and then posted my ranting reply 3 times making me look like a super ass then i could not delete due to time delay and couldn't login my laptop n phone nearly got it.
B. Network error this morning.
C. Notification not working properly
D. I got zero logs in my participation tab
Using sau app android.
Also use http website.
I wonder what played up.
Oh btw i do read wasteland sorry if you guy's feel that im not hear it just that im on at reallllly creepy times due to work then its upside-down when im on nightshift for a week lol.
4am fast scroll then im on at 8pm for a little bit.
Mardie station aka 100km south of karatha 1hr from panawonica
Not been long in fifo just started out couple months back just to help my house build come along with ease.
New house is a nightmare. Ill buy established next time. Or a smaller block of land btw bigger not always better.
Ah okay. Are operations there slowing down? Heard Karratha is slowly going dead. Have a few guys with property up there just letting it default cause they can't get any rent or sell it at all even at really low prices
One thing i love doing is compare the pair and shop around to make sure your happy give totaltools shop a go they are new and big range might find find a few more pieces for a bit extra. As for me i still dream for a home toolbox im in the market too if wifey allows.
  • Like 1
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
