50 minutes ago, shoey85 said:
Any one experience a water pump bearing or idler pully failure? I think I have had one die on me, belt screech and a typical knocking from a bearing FFS, back to Mark tomorrow!
Yep had a pootrol come in last week with "squealy belt". Water pump bearing had let go and was screaming its box off
  • Like 1
So went to Mark and he basically knew what it was after 10 seconds, my alternator came lose and the bolt was hitting the fan, he fixed it up on the spot[emoji4] then sent me to get him a carton [emoji482] all good drove it home [emoji6]
  • Like 2
2 hours ago, shoey85 said:
So went to Mark and he basically knew what it was after 10 seconds, my alternator came lose and the bolt was hitting the fan, he fixed it up on the spotemoji4.png then sent me to get him a carton emoji482.png all good drove it home emoji6.png
This is one of the reasons I love C-Red.
  • Like 1
Found this post in trending
Wonder if anyone can help.
Btw in sau app do you find it hard to find this thread ? ?
Subscribe to topic.
I just use "participated" most of the time and it's always not too far down
  • Like 2
Yeah nah i think im having more then general issues.
Eg.. my http link did not post ive had no participate activities in the lasth months or so and that what i use to use and now just finding this thread was a challenge but i re subscribe to it.
Time will tell until the next update.
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
