10 hours ago, dan_the_man said:
ElleAli76 - is she looking to get her email validated?
Hory shit! It's Dan!
5 minutes ago, turboedsloth said:
Get her to try it now
Corey, I called you yesterday, not feeling the love of a return call :(
Going to rip the box out of the yolodeo, can I send it down to you for fixing if it's not completely fkd? If it is I'll look for a 2nd hand one.
It's the sau mail servers. It started telling me I needed to change my email as my email is rejecting the emails from sau. But I still receive emails. Then it basically locked me out after two days.
  • Like 1
You Has email, Jade couldn't tell which Lachy you were. But yeah thats no problem
  • Like 1
Yup exactly!
:O
I thought Jade and I was tight :(
I haz no email yet, but will look out for it.
Engine conversion sounds fun but I just need the yolodeo going so that I can fix and sell the Datsun, so that I can get cracking on 2017: Year of the triangle
  • Like 2
2 minutes ago, turboedsloth said:
Sell the datsun you say???  Is it really a short mans ute?
Short-ish? The shorter you are the better you'll fit for sure.
I'm 5'11" and sit in it reasonably comfy, 6'1" maybe the limits before it gets stupid. Definitely for lighter gents such as myself, if you had a few extra kilos I'd suggest converting the front to coilovers so you can put some stronger spring rates in.
In saying that one of my customers from Narrogin (who's bigger than you, maybe 6'5"+) told me of the time his mate picked him up in a Datsun 1000, his mate being a former golden gloves boxer. So big guys can fit!
It might end up an option as a new workshop ute. My triton is dying slowly
Nice.
Well when I'm happy with it, I'll let you know. Also needs a radiator fan.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
