13 minutes ago, Manne said:
That's what is sounds like.
I'm not sure if my car can handle a spirited drive in the hills right now, we'll see what happens on the day.
Bike?
I could do, but I'm not sure if Riding in the hills at night is a smart idea or not, Seen too many accidents.
Yer nah night a tight roads possible gumnuts.
Better in car. She handle it its a drive not a track day [emoji39]
8 hours ago, Hank Scorpio said:
So is the plan to meet at the Tavern and then do a short drive after the meal?
Yes meet at Tavern
Meet each other if its a big turn out then stand etc..
But if reasonable secure a table and have a seat (most likely outside) and smash some pizza.
After that a drive would be nice.
30mins
Or
1hr.
Up to you guys but i have to post by Friday on the event page.
  • Like 1
Yes meet at Tavern
30mins
Or
1hr.
Sounds like a great idea. Meet at Tavern, 30 minute drive afterwards to a meeting point, say good night and head home [emoji106]
  • Like 3
Ok so i think i found what i want but there is no pictures or diagrams of where that part belongs On the website.
So i thought if i go to nissan give him my vin or part number he have a look so.
He said only OEM parts he can find that belongs to the car he than said the part number should not start with a letter so what i gave him was no good.
He also said dealer option wound not come up....?
1486004404099.thumb.jpg.3f602892f78443e0
Dose that website if i contact them do you think they got the digram where it belongs.
No idea, however lots of genuine Nissan part numbers start with a 'K'.
http://nissan.epc-data.com/skyline/bcnr33/3940-rb26dett/misc/F80/
'6935' seems to refer to a "console finisher", I reckon you're about on the money mate.
  • Like 1
you buying cf dash pieces for the 33?  WHere from ?
Have you tried Robsons in Singapore - there kit / work is amazing.
Im keen as well - can get 2 sets perhaps?
Dan
Ok yer ill have a look but im more keen on oem or nismo.
makes the gtr shine with more pride!
Would be more annoying when driving and looking at it think only if it was made by nismo. Haha im loosing my mind [emoji38]
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
