Wtf how dare my phone change God to rajab. I find this deeply concerning?
There are a few words on the forum that auto change due to language or just for the lulz.
Such as tur-key becomes the sphincter of the universe
  • Like 3
Compression test shows
1=150
2=155
3=155
4=150
5=155
6=150
Intercooler is full of oil again, proberly about 2l worth lol.... catchcan and overflow bottle is oil but relativly empty. Guess its new turbo time, injectors and ecu time
1=150
2=155
3=155
4=150
5=155
6=150
That's good news. Thought it may have been a ringland as they are so common.
When I stripped mine at 180k it had 5 broken ringlands but only 1 was letting oil past
has any one got one laying around there not using. I would like to see if i can get my dash boost gauge working again. 58d5c9477d71d_boostsender.jpg.ea7764faf13d61475f1a005c6bfd09bb.jpg
Ahh so that what it is i was wondering why i hot a floppy tube and gauge not working. I still will be maxing it out tho [emoji12]
I suspected ringland failure amd it still mite be, but to have comps that high i think there ok. My motor got a work out Thursday night so i suspect that finishwd the turbo off. Original turbo from new on 176k, its done well
  • Like 1
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
