11 hours ago, R33kizza said:
Has it ever had a coolant flush? Different coolant colours have different additives to stop issues like this
Last coolant change was the issue I think.
Its only ever had 1 other change, done at the end of the warranty with dealer coolant. Just did the 90 000km service, thought I would slip a coolant change in 10K km early because I had it on a hoist and it was easy to do, and ever since it has been spitting o-rings and seals all over the place.
Change was made to the Nulon red. I am fkn kicking myself as I usually just use a glycol concetrate and distilled water mixed by me, but I got sucked in to the easy route and now I am paying for it :(
  • Sad 1
10 hours ago, Beyond Blue R33 said:
If you need parts my mate is a service manager at Ford. If you can't be assed chewing out the stuffed old back I could put a good word in for you to get it fixed:-) p.m.
I will probably take you up on this.
I actually bought this car, because a past member on here was a Ford parts manager, and he saved me literally thousands when i bought it, and made sure it left the stealership with some pretty noice ad ons
I miss bardley :(
I miss bardley [emoji20]
Bring it to Bunbury and I’ll help you out for a chilli dawg and carton.
Doing it at yours might be do-able but not sure when
I cant do shit, and no one should do a job like this for free
On 13/03/2018 at 8:35 PM, Beyond Blue R33 said:
On 13/03/2018 at 8:29 PM, t_revz said:
My latest multi meter was run over by a Ute months back and is now starting to tell lies. Might order a newbie tomorrow
Every time I go to contract power/mtu/cat/Detroit/speno rail there are blokes running with fluke meters. The bro swears by them.
morning all, I am about to head off to ross auctions there is a police unclaimed goods auction on there starts in about 45mins but item 200 I think has a fluke meter by the looks of it or something? but if anyone has a look at the catalog and would like for me to bid on or see anything for them feel free to holla.
  • Like 2
Anything good show up?
So, I have to fkn rant about this or my head will fkn explode.
Every one has those soccer mum type friends that leach their way into your circle of FB etc, right?
Well, somehow I ended up with one of these twatty bourgeois bitches on my feed, and paid little to no attention to it, untill it recently posted a pic of the damage from someone ALMOST running up the back end of its car. I say ALMOST because from the pic its pretty obvious its was a very glancing blow (car was repaired and returned to her in a little over a week)
27972261_1436425436468402_1738560382053399534_n.jpg.87651756ebad20a7db35118aabb917fe.jpg
I STILL didnt pay much attention, until this little gem popped up a little later
Now, its that last sentence that burns my arse like a bad late night burrito, as a frequent payer of compulsory third party insurnace premiums on my rego.
Anyone want to comment on a suitable reaction? Because a public expletive filled rant at the POS on FB just doesnt cut it when they can just delete/report me for it.
Just tell her you reported her for fraud, that will shut her up
  • Like 1
Her reflection whilst taking the picture indicates no issues. The damage to the vehicle indicates a very minor graze. There is no damage to the rim and I expect she may have heard the tap but certainly wouldn't have felt much. Broken ribs etc. I call BS.
Ultrasound and Xray show what!!!!
I would suggest she just lays down from now on and never leaves the house as her body must be made of glass.  She could die at any moment
 imagine if she fell over!
Walmart epic fails. [emoji26][emoji122][emoji61][emoji54]
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
