I've got some sort of Power-Drain going on with the car.
Left it on charge overnight last night and it didn't move an inch. disconnected the battery and it immediately started to charge.
This isn't going to be fun.
How big/fast is the charger?
On 8/31/2018 at 9:41 AM, Hank Scorpio said:
I've asked rotos for a new box.
You wouldn't have that rotary shit there, would ya Corey?
I have put the feelers out on Saturday night. A few guys have changed up to sequential's so may have 1 laying around
Im not 100% sure, It has little lights which light up (8 in total and when I tried to start the car it was at 6/8).
Got a multimeter?
Don’t run a charger on the car if it has no battery. Or the charger will run flat out and the voltage could go high and cook the electronics
That's what I should have done to begin with, hindsight is a beautiful thing though.
I was orginially working towards an event that didn't come to fruition, would have given me longer and more money to build the car initially, but it didn't work out that way.
Also, 1 guy straight away said put a T56 in it and proceeded to show me the bell housing adapter i sent you ?
If said guy would like to fund my T56 conversion, you can tell him that I'm keen to get it done. However wheels/tyres and a lift on the Humvee is more important than the Cosmo.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
