Why not just buy a known working engine and save yourself the headache. They're cheap enough.
Look up rods and pistons then add in you may be up for a crank also depending on how bad the damage is. Add on the cost of machining and assembly. For allllll of that you could buy two (possibly more) working stockers.
  • Like 1
solved that misconception then.
its the same as asking how much for a respray.
depends whats broken, what issues arrise when you start, how far do you want or need to go, what parts your using, how much your paying per hour, how long it takes.
Its not hard asking people to help you.
They also don't have to help you.
Take charge of your life and do things for yourself. You will gain knowledge and a fulfilling sense of achievement.
It will set a good example for those around you.
  • Like 3
I didn't actually think it would be this hard just to jump online and ask if anyone had done this before and find out an approximate cost...
My bill was $3000. That included machining and the cost to screw it together.
That DID NOT include oil pump, water pump, set of pistons, head gasket or any of the other parts you may change.
Buying something "cheap" because it's busted only to spend what you saved plus much more doesn't seem a good plan.
  • Like 1
To fully rebuild an engine and make it stronger with forged pistons rods etc.
Got quoted about 10k from race pace - Their quality of work is top notch tho
Its all depends on how much you want to spend.
IMO, Its better to just buy a second hand engine, but I prefer to rebuild it so it lasts and I have no future headaches -
Appears there are so many arrogant pricks on this forum, be alot easier to just answer the kids genuine question
Edited by MariahCarey
  • Like 1
I would have to agree the guy only asked an approx cost. Few ego problems
Good on you piggaz :)
Because we all have different engine builders
I paid 7k for a build that had nothing but issues before it went bang
could easily pay 20k + to get something half decent and that doesnt include things like turbos and manifolds
For a R33 Rb25det, it really needs the pistons and valve springs, its a good idea to have it properly built then saving coins. Mine cost about $5G to rebuild including CP pistons, Supertech valve springs plus other bits and pieces.
Well - I ended up cracking my block.
bending my crank
putting metal through my turbos
blowing up my oil pump
putting metal through oil cooler.
cleaning head
machining head
checking new block
getting new bearings
pistons
rods
head gasket
valve springs retainers and guides
new oil pump etc etc
So its cost over $20k.
So lets say a basic build could be $5k. Full forged build with heaps the goodies and pretty much worst case engine damage.....$20k
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
