timmy_89 Posted May 20, 2015 Share Posted May 20, 2015 Hi all, I have recently purchased this brake adaptor kit for my R34 GTT, and after learning of my involvement on Skylines Australia, Alpha Omega Racing has offered a discount saving to all SAU members. Company: Alpha Omega Racing www.alphaomegaracing.com Product: Evo 350mm Brembo Brake Adaptor Kit. The adaptors are 100% CNC machined billet alloy, grade 7075, which is super lightweight and high strength. There is also a 'Stealth Edition' kit available, where the adaptors are anodised black. Purpose:The kit allows you to fit Brembo calipers from an Evo 5-9 (all the same) with Evo X rotors (350mm, much larger than the 320mm used on previous Evo's) to your R32/R33/R34/S13 (5 stud)/S14/S15/Z32/Z33. The reason for not using the Evo X caliper is because they have larger 'legs' which would require the adaptor to be smaller/weaker. The Brembo calipers on the Evo's have a slightly larger pad area than the GTR Brembo's, as well as larger pistons, and can often be bought significantly cheaper too. What's included: - Pair of CNC machined 7075 billet alloy caliper adaptors - High tensile bolts and washers - Installation instructions (with pictures) What you need to get - B.Y.O. or supplied by Alpha Omega Racing: - Mitsubishi Evo 5/6/7/8/9 Brembo front calipers (including pads/pins/shims/clips/banjo bolts) - Mitsubishi Evo X front rotors (350x32mm) - Custom brake lines Alpha Omega Racing can supply all of the above, but you are also able to purchase the parts elsewhere if you wish. I personally sourced the parts elsewhere as I decided to go for 2 piece Attkd rotors and had a local business make my brake lines as I use them regularly for other custom lines. Some people may find it more convenient to purchase all parts for the conversion from Alpha Omega Racing and the listed prices are as follows; - Evo 5/6/7/8/9 Brembo front calipers (used) - $850 - RDA Evo X 350x32mm slotted rotors - $290 - Goodridge custom brake lines - $240 Alpha Omega Racing can also offer services to rebuild your used calipers, powder coat them, or even install the whole kit. Wheel clearance: Minimum of 17" race style wheels with good clearance are required. Brake Master Cylinder: You are able to retain your factory brake master cylinder, however it is recommended to upgrade to a brake master cylinder with a piston size of 17/16" (such as a BM57). Price: The RRP for the adaptor kit is $370 plus postage, or $385 for the 'Stealth Edition' adaptor kit plus postage. The group buy discount that is being offered is; - <5 people = no discount - 5-11 people = Normal kit for $340ea, or 'Stealth Edition' kit for $355ea, (save $30) plus postage - 12-19 people = Normal kit for $310ea, or 'Stealth Edition' kit for $325ea, (save $60) plus postage - 20+ people = As above, with free postage - including tracking number/signature on delivery/insurance (total saving of approximately $90-110) Group Buy Condition: The group buy will run for a two (2) week period, finishing at close of business on 4th June 2015. Anybody interested in purchasing the kit as part of the group buy should notify my by the cut off date and I will add them to the 'buyer list'. At the conclusion of the group buy period I will tally the number of buyers and contact Alpha Omega with the total numbers. A discount coupon will be provided to each buyer allowing them to get the appropriate discount. Prior to the cut off date all communication will be with me either via this thread or via PM. At the conclusion of the group buy, once you have been provided with the discount code, all communication will be between the buyer and Alpha Omega. All shipping and payment details will be between the buyer and Alpha Omega only. Any warranty on the product(s) will be provided by Alpha Omega. Pictures: Adaptor kit Nissan Silvia S15 with Enkei NT03 wheels 17x9 +15 Nissan Skyline R32 GTR with LM-GT4 18x9.5 +12 If you have any questions please don't hesitate to ask. Cheers, Tim Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/ Share on other sites More sharing options...
DekA Posted May 21, 2015 Share Posted May 21, 2015 Sign me up Tim 1 Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7537467 Share on other sites More sharing options...
timmy_89 Posted May 21, 2015 Author Share Posted May 21, 2015 Added to the list Matt. I also forgot to mention that the adaptors are are both engineered and made in Australia. Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7537482 Share on other sites More sharing options...
DekA Posted May 21, 2015 Share Posted May 21, 2015 Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7537492 Share on other sites More sharing options...
Pezhead Posted May 23, 2015 Share Posted May 23, 2015 I run this set up and it's great. 2 Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7538780 Share on other sites More sharing options...
GTR_JOEY Posted May 23, 2015 Share Posted May 23, 2015 I also have this kit on my car, the black 32 is mine They are a great upgrade and look boss too 1 Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7538782 Share on other sites More sharing options...
SABBAi Posted May 25, 2015 Share Posted May 25, 2015 I'm in Tim. 1 Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7539853 Share on other sites More sharing options...
luke gtr Posted May 26, 2015 Share Posted May 26, 2015 I have brake kit, but still interested in this. Any chance of rear set being developed? Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7540607 Share on other sites More sharing options...
GTR_JOEY Posted May 26, 2015 Share Posted May 26, 2015 The rear kit is in development now, I'll get the specs off wing if your interested Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7540611 Share on other sites More sharing options...
Alexro Posted May 26, 2015 Share Posted May 26, 2015 interested in rear kit Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7540627 Share on other sites More sharing options...
timmy_89 Posted May 26, 2015 Author Share Posted May 26, 2015 As GTR_JOEY has already mentioned, a rear kit is in development. I believe this will be incorporating the rear Evo calipers with the 370Z 350x20mm rear rotors. At this stage I do not believe there is an ETA on this kit. I will chat to Alpha Omega at the completion of this group buy about the possibility or a future group buy on the rear adaptor kit also. Just confirming at this stage the following people are committed: - DekA - SABBAi luke gtr if you would like any more information please don't hesitate to ask. Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7540676 Share on other sites More sharing options...
GTR_JOEY Posted May 26, 2015 Share Posted May 26, 2015 Yep as above^ This kit with stock rear is a 76:24 bias ratio This kit with the new rear kit is theoretically a 69:31 bias Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7540721 Share on other sites More sharing options...
Gareth Posted May 29, 2015 Share Posted May 29, 2015 What do you run on the rear Joey? Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7542287 Share on other sites More sharing options...
GTR_JOEY Posted May 29, 2015 Share Posted May 29, 2015 Stock mate, cars not running atm though Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7542294 Share on other sites More sharing options...
Scooby Posted May 29, 2015 Share Posted May 29, 2015 Yep as above^ This kit with stock rear is a 76:24 bias ratio This kit with the new rear kit is theoretically a 69:31 bias Joey any idea what the stock bias is? Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7542316 Share on other sites More sharing options...
GTR_JOEY Posted May 29, 2015 Share Posted May 29, 2015 Not sure man, I didn't do those calculations Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7542317 Share on other sites More sharing options...
timmy_89 Posted May 31, 2015 Author Share Posted May 31, 2015 Just a reminder that the group buy will closed this Thursday at 6PM. Currently the only people confirmed are: - Deka - SABBAi There needs to be at least 5 people in order to get some form of group saving. Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7543008 Share on other sites More sharing options...
Dale FZ1 Posted May 31, 2015 Share Posted May 31, 2015 Email sent Tim, confirmed interest Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7543183 Share on other sites More sharing options...
SABBAi Posted May 31, 2015 Share Posted May 31, 2015 Will sprrad the word with the Stagea crowd. Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7543184 Share on other sites More sharing options...
luke gtr Posted May 31, 2015 Share Posted May 31, 2015 I'll wait until they're finished the rears. Cars not even running yet, so, ive got time. Looking forward to seeing these kits fitted. Link to comment https://www.sau.com.au/forums/topic/456804-evo-350mm-brembo-brake-adaptor-kit-to-suit-r32r33r34s13-5-studs14s15z32z3/#findComment-7543210 Share on other sites More sharing options...
