Hi all,
I have recently purchased this brake adaptor kit for my R34 GTT, and after learning of my involvement on Skylines Australia, Alpha Omega Racing has offered a discount saving to all SAU members.
Company:
Alpha Omega Racing
www.alphaomegaracing.com
Product:
Evo 350mm Brembo Brake Adaptor Kit. The adaptors are 100% CNC machined billet alloy, grade 7075, which is super lightweight and high strength. There is also a 'Stealth Edition' kit available, where the adaptors are anodised black.
Purpose:
The kit allows you to fit Brembo calipers from an Evo 5-9 (all the same) with Evo X rotors (350mm, much larger than the 320mm used on previous Evo's) to your R32/R33/R34/S13 (5 stud)/S14/S15/Z32/Z33. The reason for not using the Evo X caliper is because they have larger 'legs' which would require the adaptor to be smaller/weaker. The Brembo calipers on the Evo's have a slightly larger pad area than the GTR Brembo's, as well as larger pistons, and can often be bought significantly cheaper too.
What's included:
- Pair of CNC machined 7075 billet alloy caliper adaptors
- High tensile bolts and washers
- Installation instructions (with pictures)
What you need to get - B.Y.O. or supplied by Alpha Omega Racing:
- Mitsubishi Evo 5/6/7/8/9 Brembo front calipers (including pads/pins/shims/clips/banjo bolts)
- Mitsubishi Evo X front rotors (350x32mm)
- Custom brake lines
Alpha Omega Racing can supply all of the above, but you are also able to purchase the parts elsewhere if you wish. I personally sourced the parts elsewhere as I decided to go for 2 piece Attkd rotors and had a local business make my brake lines as I use them regularly for other custom lines. Some people may find it more convenient to purchase all parts for the conversion from Alpha Omega Racing and the listed prices are as follows;
- Evo 5/6/7/8/9 Brembo front calipers (used) - $850
- RDA Evo X 350x32mm slotted rotors - $290
- Goodridge custom brake lines - $240
Alpha Omega Racing can also offer services to rebuild your used calipers, powder coat them, or even install the whole kit.
Wheel clearance:
Minimum of 17" race style wheels with good clearance are required.
Brake Master Cylinder:
You are able to retain your factory brake master cylinder, however it is recommended to upgrade to a brake master cylinder with a piston size of 17/16" (such as a BM57).
Price:
The RRP for the adaptor kit is $370 plus postage, or $385 for the 'Stealth Edition' adaptor kit plus postage. The group buy discount that is being offered is;
- <5 people = no discount
- 5-11 people = Normal kit for $340ea, or 'Stealth Edition' kit for $355ea, (save $30) plus postage
- 12-19 people = Normal kit for $310ea, or 'Stealth Edition' kit for $325ea, (save $60) plus postage
- 20+ people = As above, with free postage - including tracking number/signature on delivery/insurance (total saving of approximately $90-110)
Group Buy Condition:
The group buy will run for a two (2) week period, finishing at close of business on 4th June 2015. Anybody interested in purchasing the kit as part of the group buy should notify my by the cut off date and I will add them to the 'buyer list'. At the conclusion of the group buy period I will tally the number of buyers and contact Alpha Omega with the total numbers. A discount coupon will be provided to each buyer allowing them to get the appropriate discount.
Prior to the cut off date all communication will be with me either via this thread or via PM. At the conclusion of the group buy, once you have been provided with the discount code, all communication will be between the buyer and Alpha Omega. All shipping and payment details will be between the buyer and Alpha Omega only. Any warranty on the product(s) will be provided by Alpha Omega.
Pictures:
Adaptor kit
Nissan Silvia S15 with Enkei NT03 wheels 17x9 +15
Nissan Skyline R32 GTR with LM-GT4 18x9.5 +12
If you have any questions please don't hesitate to ask.
Cheers,
Tim
As GTR_JOEY has already mentioned, a rear kit is in development. I believe this will be incorporating the rear Evo calipers with the 370Z 350x20mm rear rotors. At this stage I do not believe there is an ETA on this kit. I will chat to Alpha Omega at the completion of this group buy about the possibility or a future group buy on the rear adaptor kit also.
Just confirming at this stage the following people are committed:
- DekA
- SABBAi
luke gtr if you would like any more information please don't hesitate to ask.
Just a reminder that the group buy will closed this Thursday at 6PM.
Currently the only people confirmed are:
- Deka
- SABBAi
There needs to be at least 5 people in order to get some form of group saving.
I'll wait until they're finished the rears.
Cars not even running yet, so, ive got time.
Looking forward to seeing these kits fitted.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
