  • Replies 92
So what car(s) are we looking for Duncan when Roy comes over to watch the video I taped.
I remember now the Beemer killer was a brunette.
Hint: It's listed under her name :Oops:
"The faster you are going the less time there is to concentrate on actually learning to drive."
I agree totally with this. I learned more about the track in two slow laps in the rain than the whole 200k I did in the dry at full pace.
Snowman / Roy - If we were to get anything going with the Dutton we would need to make moves (decisions) in that direction very quickly. Money to spend on the car is my problem and a small sponsor would help. I can come up with entrace fee, but would like to spend more on car to become competitive with the R34 and others. But at the end of the day I would be there for sure.
Christ, did someone actually get one of those understeering, too short, breathless barges to go well enough to enter an event?
I hear europe got a suspension package that fixed the handling, but I hated the local hatch I drove. BTW I realise they call them a coupe, but it's a 3 door hatch OK.
Anyway well done Kel. We'll be taking a long hard look.
I also understand Kero (Fats brother) has a cd copy now after some thread searching. Mine is also welcome to be borrowed but is taped at 1/4 speed so you may need my video which is a permanent wife accessory for lifestyle programs.
BTW - Roy - what happened with you and Chris and the Dutton? Or is that to be discussed based upon results of your R32?
Its a possibility, but its a little too late to get sponsors, i could get my hands on enough money to do the event, but would have to pull out of a commitment i have already mate to a crew with a team for the BP Rally the same wekend.
I think it may be best to wait fot he PIARC day later that month, may even have some new brakes to be sure not to fall off the island. :Oops:
Oops sorry Kel posting the *slight* off pic. Didn't mean to put that one up.
That's okay, you'll also see me killing a witches hat in the Speedweek coverage :Oops:
For the record though, that pic is of my co-driver Dan.
Not sure how useful we'll be but happy to let anyone entered in the Vic Dutton pick our brains (well, maybe I need to revise that reference since Fatz was on the team!).
My main tip- if you're not going to win, do something spectacular!
That was a well wicked weekend guys!!!
Oh, and I was driving a TX5 not an MX5 Snowman!
I have got 1 or 2 pics too. When I get around to it, I'll upload them. Including one of Roy in his secret machine....
Go Team Wang!!!
Go Team Wang!!!
Chrisman...LOL...welcome to SAU :)
Id like a few photos for my own archive, but for hopefully obvious reasons i hope you appreciate why id rather not have pictures of the car on a public forum... :(
Kel, what punishment was there for Majanal emulating Fatz in the 350Z? I think you should have taken his beer rations away from him :)
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
