OK spark plug, cam and timing belt covers sold. Still for sale:
6 Volk Racing Le37 in 18x9.5 +12 $2,500
Wideband 02 sensor controller $180
Battery Box $20
2x 32 Heater core and box $80
JJR RB26 sump baffles $250
R34 GTT/C34 Stagea Series 2 Oxygen Sensor $90
Ruzic Datalogger and Engine Monitor II $500
Plenum $200
Walbro e85 fuel safe pump $200
  • Replies 43
  • 3 months later...
Walbro fuel pump gone.
Now added, radiator cooling panel to suit W34 Stagea from the original Bass Junky group buy, $150
So the current list of for sale is:
Battery Box $20
RB26 Plenum $200
Stagea Cooling Panel $150
Sorry yes the plenum is bare other than the air temp sensor; although if you need particular bits I probably have them...
Re the Ruzic Data logger.  Basically Paul Ruzic (Mountainrunner on here) was (is?) a skyline owner and electrical engineer who built limited runs of a couple of excellent units.  I'm selling the Engine Monitor and Data logger, they work together to monitor 23 channels of data, and bring them to your attention if there is an issue (eg low oil pressure, high oil or water temp etc etc).  It comes with software to configure each of the inputs.
When an alarm is triggered you can get warning light and/or buzzer, it also comes with a shift light and the EM has a configurable screen than can show 4 pages of 4 values.
You (or an auto elec, or a good workshop) will need to wire in whichever data you want to log. I had oil temp and pressure, coolant temp, fuel pressure, revs, volts, speed, rpm, 4wd%, afms, air temp, injector%, timing, TPS, wide band 02, brake switch, engine check light. And GPS location and speed of course
Available channels for the Engine monitor:
Available channels for the Data Logger:
The 2 units share data so all DL channels can trigger warnings, and all EM channels can be logged.  It logs to a USB stick for easy changes and transfer to a PC
There must be a few engine monitors out there because I got one from the second batch, not sure how many data loggers he made.  Also his attessa controller (which I don't have) is excellent and links in too.
When I decied to go e85 with flex fuel I went Haltech, as part of the change I went to their dash as well to keep the car simple.
  • 2 months later...
lol, you mean other than a major PITA?  I'll check something out but I don't have access to anything other than retail couriers
  • 3 months later...
  • 3 years later...
46 minutes ago, RobsgottaGTR said:
I am interested in the wheels!  Ready to purchase.  Message me here or on Instagram @robs_gotta_gtr
PM sent!
  • Like 1
Yeah it's been a while, but not everything is sold...I need to recheck everything and probably just start a fresh thread
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
