Entries Open: Sauvic Deca - 25th July 2015 - Shepparton - Its Back!
Yeah that's my concern, that looked sketchy in that recent vid in the dry.... no real run off there... tree's oh god the tree's.
Ah don't be a pussy!
You can go as hard or not as hard as you like, often slower can be a bit faster (especially in the wet). So it's only dangerous if the pilot is being dangerous :)
Given how wet I was one year, after standing in the torrential rain for a good 15mins directing cars, safe to say no matter what the event goes on! Viva la DECA!
(I may or may not bring cheater EVO if weather looks sketchy lol).
Considering the event starts at 7:30 and is nearly 2 hours away, even for northies, you might want to reconsider your departure strategy :thumbsup:
  • Like 1
Thanks for confirming event start Birds.
Amend departure time to 5.30am @ Greensborough, this should give ample time to arrive following scrutineering and driver debrief.
If there is not many people interested in driving up, I'll just head off per own schedule.
Cheers
I used to leave eastern suburbs latest 5am back when deca started 8am...
Just in case anything goes wrong or you have to sort out anything with your car and scrutineering/licensing it's always a good idea to get there early rather than on the dot!
think there 10+ spots left so get it in, should be plenty of runs for every-one with the limited entries.
I've got the CAMS license, mate who's done a DECA with us before is coming too, just getting AASA posted in the mail today.
Oh yeah, we're sharing the same car (mx5 - nohomo)
Do we just apply separately?
go though the online form and you will see an option for shared car.
both need to put though an entry but mark that you sharing car so you get put in same group a bit apart so you have time.
I remember that day.
Submitted and paid!
Good stuff Jack! You and Jarrard?
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
