Hi all
I'm installing a hks gt-rs turbo on my r34 GTT. Read that I should prime it before I drive and to do that I need to cut the fuel supply or ignition. Could anyone recommend which I should do? Would I just remove a fuse and if so does anyone know which one? Also if anyone has any tips like pouring oil directly into the turbo before etc feel free to share! :)
Cheers
https://www.sau.com.au/forums/topic/458006-turbo-install-cut-fuel-or-ignition/
Seriously people build engines without worrying about it, within a second or 2 of starting your whole engine gets oil pressure, some just squirt some oil in before fitting the oil line on.
If you want to sit there cranking it, remove the spark plugs to make cranking easy and it automatically kills spark and kicks out any injected fuel out through the plug holes.
Yeah that's what I've read, but I've also read that you could potentially kill a turbo in the first few seconds so I'd rather not risk it
Also I'm running a return flow fmic so there's all the piping above the spark plugs and I'd really like to do that as a last resort considering that'll take an hour or so to remove everything and re torque the plugs along with trying to fit that darn bitch of a pipe back up to the plenum inlet and fmic joint
No one has ever killed a turbo with oil starvation at first start up. If that actually happened it would have been a DOA turbo anyway.
When you do an oil change and fit a dry filter the whole engine runs with no oil pressure for 4-6 seconds
I put a capful of oil into the turbo itself once installed (into the oil inlet hole, to be specific, eg don't go pouring it into the compressor outlet), then put on the oilfeed line. I usually change the oil whenever installing a new turbo too, and crank the engine till oil pressure light goes off (if you have an immobiliser fitted you don't need to pull any fuses etc, it already won't start), then start her up. Drive normally till at operating temperature, then turn car off, go inside and play Street Fighter 2 Hyper edition on SNES, and let car cool down completely. My theory on that being let seals/bearings etc reach operating temperature before being subject to excessive load, and then all settle into place as they cool down, after going through a heat cycle. Maybe not needed but I've never had any turbo issues, they have all lasted 30,000 years doing it that way.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
