2 hours ago, admS15 said:
Which is why 8374 makes sense. Isn't that right Grant??
Na, twin EFR's is better.
Cos it's one more than one hey Bill?
  • Like 1
2 hours ago, r32-25t said:
That kit is far to untidy,
Wrap the bonnet with a photo of stock engine bay, that way you'll look at it and say "that's tidy engine bay" :P
Sent the rocker cover out to craved coatings and got it done to match the rest of them IMG_4744.thumb.JPG.6afa6134301a3d4fee17e346f645c60a.JPGam going to uncover the writing on it due to the candy looking different there compared to the rest
  • Like 1
Did some work on it over the weekend, fist pulled the timing belt off and inlet cam cover off
and new cam in for clearence measuringIMG_4811.thumb.JPG.d6fef983e41a59b5e176ea8d2d79bc1e.JPG
6 of the clearances are out of spec and the shims have been ordered and should hopefully be here in the next couple of days
  • Like 1
Parts are back from ceramic coating IMG_4822.thumb.JPG.5cf3f8ee475476153faf90d50043a1e0.JPGi also bought plugs for the original oxygen sensors because I no longer use them and they will just be in the way when installing the turbos
  • Like 3
Had a couple of hours over the weekend to work on itIMG_4827.thumb.JPG.3af7f04e2cb1aed102f7d208a5971def.JPGthe shims had arrived a few days before an i fitted them, checked the clearances were spot on
IMG_4828.thumb.JPG.3db9bfcd9c9a8326e7ccd08c1287e64e.JPGthen moved onto the cam gears and timing belt
  • Like 3
I then grabbed a die grander with basically a scotch bright pad on it and attacked the powder coatIMG_4833.thumb.JPG.7f2c88345b2389c350619f4fe737f249.JPG halfway done
IMG_4834.thumb.JPG.2353981157b2bd15f90050fd90bca345.JPGpowder coat gone and then I ran another pad over it to give it a machined look
IMG_4835.thumb.JPG.7c791d0e52471563868b131866efcdd9.JPGand the finished product
  • Like 1
Then got to fitting it to the engine IMG_4836.thumb.JPG.04867ea540bf3c0762a2b3f6934ce1f5.JPGhere it is fitted to the engine
IMG_4837.thumb.JPG.df0c7aade7b3e1f6dac59e3e349b01ce.JPGthis comes with the kit and of corse is the reason the kits costs so much lol
IMG_4838.thumb.JPG.a9df0418147d17669701275a29de6702.JPGand with all the sensors and oil cap fitted,
Had some time today so I decided to spend it playing with the car IMG_4822.thumb.JPG.d009be87cb63945f4e5725c08b67dc90.JPGIMG_4844.thumb.JPG.5f6d12c7e23b38252856bef4d6e73724.JPGfinally unwrapped all the parts I got ceramic coated, it's a shame you won't see them once they're installed
And finally the turbos can start going on, some people will be a bit disappointed IMG_4824.thumb.JPG.28e6ae604b5f998129b74c4849a2e97a.JPGIMG_4823.thumb.JPG.f5c51bbaee14e0635d24ed4146f4b0bc.JPGbut I'm staying twins (that was never a secret) and they are nothing specialIMG_4825.thumb.JPG.b6560843efd7188c06aba5905a80ef37.JPGjust a basic set of -5s with very low kms that I got for a price way to good to pass up
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
