I run these in my shit box, seen plenty of track days, skidpans, 8k RPM launches, etc. with the first 2x motors.
https://www.vibra-technics.com/nissan/skyline_r32_r33_r34_gt_gtr_gts_t/623/NIS240M_kit/engine_mount_r33_gts_t_rb25det_r34_gtt
And you guys know, I thrash my car when I can at the track.
Still using the same mounts, some slight vibration but nothing like a car with solid urethane ones. I get a bit of a rock with the idle braps too, extra hard c()nt at the lights.
Might be worth putting in better engine mounts(?), sounds like the stock OEM Nismo branded ones might tear with all the powahs.
 They are labeled wrong, a gtst mount and a gtr mount are completely different
Started installing the inlet manifold
put the first part on along with the drive by wire motor
then the throttles and adjusted rod for the throttles
then the new nismo plenum went on, I didn’t take the lugs off because I like the original finish
  • Like 8
22 hours ago, r32-25t said:
also fitted an oil pressure regulator against the block under the manifold
If it's an opr40, oil feed in and turbo out lines are backwards - it matters on these, it's not a fuel reg where the top 2 side ports are common inlets.
1741931481_Screenshot_20221009-122437_AdobeAcrobat.thumb.jpg.00ddaba2f8f4f6e0d370c4dfef5a1716.jpg
  • Like 3
Ok thanks glad someone picked that up, I didn’t read in the instructions and just assumed it didn’t matter. Will fix it up before I put the engine in
  • Like 3
No worries, you can just rotate it 180 but your gauge port will be unusable obviously pointing towards the block.
All good I’m not putting a gauge in it so won’t be an issue
made all the sensors fit so that the ecu knows what going on and will also allow the factory dash to be retained
built all the scavenge lines, it has 2 from the sump and one straight out the back of the head. Also has a water line from the back of the head to the water neck that the top radiator hose attaches to
engine ready to be dropped into the car
  • Like 2
By having a scavenge line from the head to the pump, doesn’t that take away from what yours trying to do? You have two points in the sump which would be “pulling down” then one at the top of the engine sucking. Kinda like a push and pull situation going on instead of all pull.
  • Like 1
On 23/10/2022 at 7:01 PM, r32-25t said:
All of them are pulling which creates a vacuum in the crankcase, unless Porsche have been getting it wrong since the 60s
Nah man, Porsche have been doing it wrong for decades 😂😂😂
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
