Ok another update! I put on the new fuel line so the car runs again with out pissing gas all over the ground. Feels good to drive again! Also, I had a package delivered a day early!! So I went ahead and put that on to.
OEM optional drink holder center console. Missing a piece or two, but its in fine overall shape!
Also made the impulse buy of new wheels. Figured they will be worth more than what I paid so I might as well get them while I can.
Nismo Omori Factory limited edition LMGT4 18x10.5 +15
  • Like 2
Wheels came in. Very nice, glad I bought them. Pretty light weight also.
Also got these cool cars for my Dad for Christmas. He collects rare/expensive hot wheels and other toy car brands. I thought these were pretty cool. Group A collection set.
  • Like 3
  • 6 months later...
  • 3 weeks later...
Haven't updated in a while. So here goes.
Got new window/door retainers and moldings. Mine aren't in terrible shape, just wanted to get new ones.
New sway bar end links for up front
New overflow reservoir
Installed the Nismo Circuit link pro up front with the front and rear sway bars
How it looked before alignment. I ended up getting around -1.8 degrees up front and -2 degrees in the back 5.5 degrees castor i think. Cant remember.
I bought these Greddy/Grex brakes like 12 years ago for my 240sx. Haven't really ran them so I decided to put them on the GTR for now. They match the advan RG well.
4 pot aluminum calipers, 330mm 2 piece rotors with duralumin gold anodized bell housings, Earls teflon lined stainless braided lines.
  • Like 2
continued from above
got a flare lol
Tomei metal turbo manifold gaskets and Greddy magnetic drain plug
New CV boots for the rear axles
Someone took a cool picture
OEM shipment for hotside
New OEM water/oil feed and return lines with HKS banjo bolts
OEM turbo gasket kit and Nismo metal intake manifold gaskets
New OEM studs, washers, bolts, nuts for turbo manifolds/turbos etc
  • Like 4
Endless BMC stopper
New OEM rear wheel bearings, hubs, nuts, washers, bolts, sway bar end links, brackets etc. Plan on doing a pretty hefty refresh since I'll be dropping the subframe for all new nismo bushings/arms.
Nismo GT L.S.D pro 1.5 way adjustable rear diff
  • Like 1
Looking fantastic mate, you are the only other person i have seen use the Nismo wrist bands to cover the reservoir. I think it's quite a nice touch. My next one will be to see if i can get my spare sit of nismo handle protectors from my cube to fit the GTR.
What catch can setup are you running? i assume nismo but i can't see it, though i could have missed it. You battery looks out of place! You should Plasti dip the bottom of the battery (the white part) black and it will blend in heaps better. I even painted both reservoirs black in my car, and taped up a strip that isn't painted so you can see the water level. But it would be a shame to do that to brand new items!
Thanks. The battery is what it came with from japan. Looks oem to me. I have no catch can installed yet. Its basically an OEM engine with basic bolt ons that I put on. I have a pile of parts for when its time to pull the motor. That will probably be the next step after I get all this suspension taken care of and installed. But I have the nismo oil/air separator that I'll be using.
"when it's time to pull the motor"
This dude knows GTR's haha
I've done 2 full rebuilds and there are still a couple of things that are "next time the motor comes out"
I'm honestly surprised you don't just buy a nismo crate motor. If i had my time again i would have just done that.
Isn't just "A nismo sticker" all you get with any nismo item?
Yes.
But at the price nismo motors are, hell they have been discontinued and you can still get them for 25k in Australia let alone bring one in. I would have saved myself 10 months worth of rebuild time, and all the little niggling issues i have had to deal with.
1 hour ago, Robzilla32 said:
What do you get for your money with a Nismo crate motor over a locally assembled engine with forged internals?
The warm and fuzzy feeling that you overpaid for what is a luke warm stock engine.
You'd have to have rocks in your head to pay those prices for a 2.6L. Honestly!!!
  • Like 1
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
