No, doing it today. If latecomers want in they'd better be quick. If we get another couple we might be able to get the discount.......and put it into postage maybe??? But sort out refunds etc afterwards.
I haven't paid yet just got this and replied:
Apologies for the delay in getting back to you - we had a 40ft container arrive and this is the first chance I've had to get back in front of the computer.
If you can shoot me your details (name/address/ph), I'll sent across an invoice with bank details on it.
Regards
So if you want in send money today asap............$251 for big mats, $232 for VSpec II mats. Sorry no R32 ones available, we tried and not possible.
Aill be great of you bring some back to NSW, willing to do the drive up to the coast and grab a few for anyone in sydney. I'm in Wentworthville so not too far from blacktown are.
Yep, just getting a new invoice then I'll pay up - been talking to the supplier this morning, they are aware of it and should supply the invoice in the next hour. The discount applies, so I will contact each of you guys in turn and get bank details etc so i can refund you each $12 per mat. And that was my reason for the delay.
But wait till i contact you please.
Me?
I'll be moving forward on this as soon as a delivery date is specified :)
Latest:
6-10 weeks to get them here - depending on how long Nissan take to ship them, and when a container leaves (which is once a month).
Once payment hits our account, I'll place the order :)
Its 10 weeks to Xmas!!!
And don't panic on payment, I ordered and paid today, he just hasn't seen it in his account yet!!!
Also starting the refund process for the discount difference....so be patient, I will get to each of you in turn.
If you see a message from me better answer it......there's money in it!!!!
Thanks Ty1, appreciated. :cheers:
My bank balance doesn't look as good now :sad:
I've now contacted all for the discount rate difference that I will refund you. Please reply with the info I need and I'll direct deposit $12 large :woot: into your account.
I'm away working this week, but will refund as soon as I get back.
Ok refunded the discount amount to most, just a few of you [i won't name and shame :no: ] who haven't yet responded with the details I need for it to happen.
I was definitely a culprit.
Sooooo, who wants me to pick some mats for them if they land in time?
Pm me if you want.
I might make it so we meet in a central location or @kila32 can come and grab them from my place.
Either way, better than being in Melbourne haha.
Unless however the boxes are to big. Actually, yolo, I'll strap them to the roof racks. I'll make it work.
  • Like 1
Still have three recalcitrants........so I have $36 sitting in my account making huge interest, be able to buy that R35 any time now [if the tax man doesn't get me]!!!!!
  • Like 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
