I dont think my battery even weighs like a kilo it's tiny, may as well be one of those little 9v batteries
You'd be surprised.
Thought my R1 battery was small but it was 4.5kg - saved nearly 4kg by using lithium. That's a lot of unsprung weight on a bike. People pay thousands for that kind of weight saving.
Phillip Island in a few weeks should be goooood I wonder what speed I'll get down the straight..
lol keep ya head down
Phillip island straight on a naked = gonna have a bad time
Why does it have anything to with the government? NBN has been a clusterf**k for a few years now. Visionstream were a primary contractor and had sack a lot of staff to reduce overheads from NBN playing hardball. Like many government backed initiatives, the cheapest bidder is selected, the price blows out due to poor estimations and general incompetence.
Whoever is in government at the time has little affect on this process.
The article I mean. Essentially blaming the government for changing the scope of the NBN and then blaming them when the project was within budget during Labour reign and now blowing out during liberal reign.
I think it works both ways
It's not beyond governments to put in measures of control for budgeting, but there are also variables you can't account for. And if delegations and contractors were lined up during a previous reign of government that's a bit difficult to control.
Forecasting an enormous project with so many variables is also very hard. I don't mind it blowing out within good reason, but when it's clear that private contractors are rorting or being rorted, that's when I feel not enough measures have been put in place or enough control exercised by governments. The insulation scheme, for example, should have been much better regulated than cheques written and contractors left to their own devices.
so want to stab some-one for that...all this money to guarentee slower internet than most of us get now.
how does it have anything to do with the gov..idiots decided to drop grom 100mbit to 25..
So spending a shit tonne of cash for the internet most of us already had/or faster.
they should have kept the original expandable system Labour had or cancelled it..which would be a better option as they cannot innovate like private business trying to clear a profit would.
^this
It's a LOT of money to drop on effectively obsolete technology.
Even if the labor model was more expensive it was the better option. This LNP clusterf**k will cost another $50 bil in a few short years when the whole thing needs to be replaced
What are you all crying about? The article clearly states that any additional funds will be raised from private investors & not government.
So relax, your precious tax income isnt being spent.
Also if you read the article instead of shouting that the sky is falling, it says:
"While 20 per cent of premises will get fibre connections, 38 per cent will get fibre to the node and 34 per cent will access the NBN using the hybrid fibre coaxial cables that supply Foxtel services."
HFC connections offer gigabit speeds & not the doomsday 25mbps.
f**k me, everyone has turned into a telecommunications engineer/capital coordinator.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
