I dont think my battery even weighs like a kilo it's tiny, may as well be one of those little 9v batteries
You'd be surprised.
Thought my R1 battery was small but it was 4.5kg - saved nearly 4kg by using lithium. That's a lot of unsprung weight on a bike. People pay thousands for that kind of weight saving.
Phillip Island in a few weeks should be goooood I wonder what speed I'll get down the straight..
lol keep ya head down
Phillip island straight on a naked = gonna have a bad time
Why does it have anything to with the government? NBN has been a clusterf**k for a few years now. Visionstream were a primary contractor and had sack a lot of staff to reduce overheads from NBN playing hardball. Like many government backed initiatives, the cheapest bidder is selected, the price blows out due to poor estimations and general incompetence.
Whoever is in government at the time has little affect on this process.
The article I mean. Essentially blaming the government for changing the scope of the NBN and then blaming them when the project was within budget during Labour reign and now blowing out during liberal reign.
I think it works both ways
It's not beyond governments to put in measures of control for budgeting, but there are also variables you can't account for. And if delegations and contractors were lined up during a previous reign of government that's a bit difficult to control.
Forecasting an enormous project with so many variables is also very hard. I don't mind it blowing out within good reason, but when it's clear that private contractors are rorting or being rorted, that's when I feel not enough measures have been put in place or enough control exercised by governments. The insulation scheme, for example, should have been much better regulated than cheques written and contractors left to their own devices.
so want to stab some-one for that...all this money to guarentee slower internet than most of us get now.
how does it have anything to do with the gov..idiots decided to drop grom 100mbit to 25..
So spending a shit tonne of cash for the internet most of us already had/or faster.
they should have kept the original expandable system Labour had or cancelled it..which would be a better option as they cannot innovate like private business trying to clear a profit would.
^this
It's a LOT of money to drop on effectively obsolete technology.
Even if the labor model was more expensive it was the better option. This LNP clusterf**k will cost another $50 bil in a few short years when the whole thing needs to be replaced
What are you all crying about? The article clearly states that any additional funds will be raised from private investors & not government.
So relax, your precious tax income isnt being spent.
Also if you read the article instead of shouting that the sky is falling, it says:
"While 20 per cent of premises will get fibre connections, 38 per cent will get fibre to the node and 34 per cent will access the NBN using the hybrid fibre coaxial cables that supply Foxtel services."
HFC connections offer gigabit speeds & not the doomsday 25mbps.
f**k me, everyone has turned into a telecommunications engineer/capital coordinator.
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
