Don't forget about the 3 million up for buy, above what we last closed at...these are people who either know it's good or are guessing it is
There'll always be panickers ready to jump ship on the off chance it's bad. That person can easily withdraw the order before announcement drops / trading resumes. I think there is a 10-15 minute window between announcement and trading resuming.
  • Like 1
I pretty much won't sell now unless it drops to like 1c... Losing what I initially put in isn't going to break me so I consider it money already spent... It'll be nice if it goes up but not gonna lose sleep if it goes down
This is the right attitude to have. The worst mistake people make is caring about the money they invested. I've learned that lesson the hard way, way too many times and finally decided to try holding this time around...it's working very well so far.
looking at a home over the week end. wish me luck dream boats <3
also, if anyone needs injectors holla.
ID1000 with adaptors to suit stock rail, plugs to suit stock loom etc $550inc gst
And I shouldn't have sold ten grand worth at 3.8 to take out my original investment
Impossible to reliably pick the best times for anything; it'll haunt you if you think about it too much. Set and forget and check the prices once or twice a day = winning. Now let's see this baby crawl past 8 cents when the news comes.
I threw another 8k at it today...I think even with the recovery the market hasn't fully digested it yet. We're sitting atop a massive discovery as confirmed by the company.
yer i bought 1k worth at .06.. seems to be worth while so far.. and 'shoulda coulda woulda bought more'
be brave to take money out of mortgage to put on this though..
got a link to this news they have?
Also, if I get non ADR approved brakes and stack my car, will insurance know? *shockworks*
Edited by UNR33L
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
