years of experience make up for a degree, unless you want upper management.
we looking for a lackey for me currently, Degree a must have, ideally some post graduate.
Wonder how he will take getting told what to do by a dropout...
Would consider me? Looking for a change in direction from management in retail....
Got a degree in mech eng with vast experience, would love to make you chai latte each morning.
/beingserious
^ This, obviously depends what you do or want to do - like if you're a teacher, doctor, lawyer etc.. makes sense.. if you do arts or science :\
& yep my boss is a 'dropout' from franga too so..
Meh I still finished high school and did a TAFE course but if I could do it all again I wouldn't of bothered with the TAFE and told 18 year old Leigh to fly free
And yeah, what are you actually looking for? I do a fair bit with security and firewalls these days.. don't you do IT security?
if that was aimed at me, then yes I usually say IT Security to shut ppl up who have no idea of the niche market I'm in.
I do very large (think national ID projects) deployments of in house PKI with a few small jobs to fill in the cracks of smaller cloud based PKI deployments and our One Time Password stuff.
Used to dabble in the SSL side of business but not so much anymore.
Hoping to be the prime for our new Single Sign on solution for the region as well, but will see.
/beingserious
It's based in bangladesh for the first 6 months at local wages...lets just say we are not hiring in AU.
anyone here been to NZ? south island specifically.
Yeah.
Pleasant place to retire. Wouldn't live there. Uncle had a proper built WRX STI, spent a fortune on it... Had to drive 200kms from his house to get 98 fuel for it. Good times
NZ have really good pies too. Mutton, venison. Mmmmmm
Yeah I been there.. Spend more time at Queenstown if you were going south island thats all I can recommend.. didn't have enough time at Queenstown.
Other than that its all nature stuff really
Went all around the south island sleeping in the back of a van.
10/10 would do again, if you like getting away from things. Queenstown was by far the biggest touristy piece of shit in the country though.
So..... milage may vary.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
