years of experience make up for a degree, unless you want upper management.
we looking for a lackey for me currently, Degree a must have, ideally some post graduate.
Wonder how he will take getting told what to do by a dropout...
Would consider me? Looking for a change in direction from management in retail....
Got a degree in mech eng with vast experience, would love to make you chai latte each morning.
/beingserious
^ This, obviously depends what you do or want to do - like if you're a teacher, doctor, lawyer etc.. makes sense.. if you do arts or science :\
& yep my boss is a 'dropout' from franga too so..
Meh I still finished high school and did a TAFE course but if I could do it all again I wouldn't of bothered with the TAFE and told 18 year old Leigh to fly free
And yeah, what are you actually looking for? I do a fair bit with security and firewalls these days.. don't you do IT security?
if that was aimed at me, then yes I usually say IT Security to shut ppl up who have no idea of the niche market I'm in.
I do very large (think national ID projects) deployments of in house PKI with a few small jobs to fill in the cracks of smaller cloud based PKI deployments and our One Time Password stuff.
Used to dabble in the SSL side of business but not so much anymore.
Hoping to be the prime for our new Single Sign on solution for the region as well, but will see.
/beingserious
It's based in bangladesh for the first 6 months at local wages...lets just say we are not hiring in AU.
anyone here been to NZ? south island specifically.
Yeah.
Pleasant place to retire. Wouldn't live there. Uncle had a proper built WRX STI, spent a fortune on it... Had to drive 200kms from his house to get 98 fuel for it. Good times
NZ have really good pies too. Mutton, venison. Mmmmmm
Yeah I been there.. Spend more time at Queenstown if you were going south island thats all I can recommend.. didn't have enough time at Queenstown.
Other than that its all nature stuff really
Went all around the south island sleeping in the back of a van.
10/10 would do again, if you like getting away from things. Queenstown was by far the biggest touristy piece of shit in the country though.
So..... milage may vary.
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
