Can't as it's residential.
Commercial property only now.
even commercial I think you cannot rent back to yourself,
expected this to be pointed out much earlier.
basiclly to avoid this.
So only way...buy penny stocks for dirt cheap.....put in a high over via your SMSF.....accept, take cash..
hope you don;t get ass raped for insider trading,
It's pretty common to rent it back to yourself, and totally legal
it's not the easiest thing in the world, lots of regulation.
SMSF's can't technically own property but this is mitigated by placing the property in a bare trust.
You then pay rent to the SMSF who pays the loan.
  • Like 1
Soooooo shitty accountant....
check
Just at tyresplus (or something in Richmond) they supply most of the Michelin and Pirelli slicks for the carerras cup and some Porsche gt3s. They have a truck of 400 slicks going to the next race meet... Most of the used slicks they get have heaps of meat on them and sell for like $100 a tyre. Maybe I'll try fit some 11" wide wheels on the pulsar.
  • Like 1
But they risk their lives on perfectly straight, prepped "no prep" roads Hamish, it has to be real?
Pac has formerly called out maatouks, if formerly calling someone out to race is an actual thing.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
