Election time... Always a tough time with an important decision to be made.
I really need to sit down and have a good think about what kind of dick and balls I'm going to draw on this year's ballot paper
hair or no hair?
Just heard an anti-Turnbull ad on the radio spoken by the ETU...had absolutely nothing to do with unions...or electricity for that matter.
Sex party gets my vote again; at least they stand for somethig tangible and desired
In Victoria the Labor party is directing it's preferences to the Sex Party
Curiously, how hard does the union push its members to vote a certain way? I knew of people back in the day who pretty much got kicked out / ostracized for voting Liberal; stopped getting offered work etc.
I think we've been sent one thing in the mail maybe a month ago, basically saying to put liberal last.. Not so much Labor first.
Liberal want to introduce some pretty f**ked up laws against tradies so it makes no sense for us to vote them in... The ETU isn't actually affiliated with the Labor party anymore though... They pretty much decide who they suggest heir members vote for on a case by case basis, I guess it's more often than not Labor as liberal doesn't really do anything for us blue collar peasants.
Labor wanna take away my pending negative gearing though, so I'm f**ked either way...
but I thought tradies all wanted to vote liberal... that's what the add told me
So I have a no junk mail sticker on mail box, when you travel overflowing mailbox is a giveaway.
why do all the political parts still deliver to me anyhow.
on a slight plus Note, I land on the morning of the election, no adds, billboards or crap for me.
look up policies from airport on way out, vote on way home go to sleep.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
