Very much depends where the car is stored and the temp you're starting it at
In the carpark beneath apartment complex, mine can be a bitch if it's gone down to 4 degrees overnight - talking 10-12 cranks. Haven't bothered to get the cold start tuned properly. Normal winter day after not having driven for 24 hours is about 2-3 cranks most.
I've left my car outside recently, covered in frost, started at 5am, water temp was something like ... low. Like "I should really consider the viscosity of this water going through engine" low. I.e, nearly frozen.
Started fine.
when e85 first hit the scene everyone had cold start issues.... then tuners worked out it's kinks
It's not really very hard to find out. What it needs is trial and error and most people aren't going to take their car back from the tuner and be happy to play with cold start settings. I was and I enjoy that so it was relatively easy to take the time to test but I can understand not wanting to pay $150 an hour over a course of a few days to get it bang on. Most people are happy as long as the thing actually starts. I am too, but I also had the tools handy to make it better, so I did that.
I agree with you re: 270rwkw, housemate has S15 with 265 AD08R's on it and I say "stop there it's fine". Nice, responsive, grip, excellent.
400kw peak power at 4500rpm and holding that peak till 7500 is great but unless I run drag tyres (and a wheelie bar) up HWY it won't translate to much forward momentum. It does have its benefits once you have grip mind you, i.e where 4500rpm is 4th gear.
Though it would be pretty lolsy getting up on 2 wheels on a traffic light drag. May have to go birds hunting.
If I go home right now and try to start my skyline, I know for a fact it won't start... It'll probably crank slowly, but there's no way it'll start before it runs out of juice... Tune needs some tweaking for sure now that it's winter and the fuel sits for many weeks at a time between starts.
Will be a case of jumpering it to another car, letting some charge come across and THEN going through the 30 seconds or so of going through short crank cycles trying to get some heat into the engine before it'll fire... And then once it starts, if I even touch the accellerator in the first few minutes of idle, it'll overfuel and cough/stall.
Wouldn't start at DECA, so I couldn't even get it off the trailer without a jump start :P
does a quick spray of start ya bastard deal with that?
Definately worth considering... Would be easier without the pod on it though :/ Hmmmmm I'll give it a crack, think I've got an old can hanging around somewhere.
from what I remember SYB is just ether and CO2 so should be fine
I wouldn't don't use wd40 or similar you will get a oily coating coating in the cooler as it condenses out.
actually never tried it on a turbo engine always just sprayed straight in intake/carby no idea how it would go with the long intake and AFM.
and a back fire could be much worse..
not sure about that idea now...
Abe from Havoc was talking me into E85. and if my engine runs or at least sounds healthier, then that is great. i wouldnt run it in a "throw as much boost and timing into as itll go" because ill have to back it off at 300. im considering doing a conservative 98 tune, see how it goes, find issues/weaknesses. then getting a separate E85 fuel map/tune made a la Birds.
tow truck driver last night tried to talk me out of E85 lol. complaining about how much fuel his subaru chews through and contaminating oil super quickly if not brought up to temp and just short drives or moving car in and out of driveway. plus i really hate the idea of having to bring multiple jerry cans to a track day.
you have a f**ken hatch back...how hard would it be?
shit for a track day with 180ish kw I need Jerry cans. once you have one who care how many more.
Don't know why people make a point about jerry cans at a track day, that's the easiest part of organising yourself for one
THIS.
have done it a few times. would not hesitate to do again
Havoc is a pipe fabricator... not a tuner...
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
