59 minutes ago, Leroy Peterson said:
in my head hot copper was like reddit for Financial Review subscribers. ...except no one makes money off reddit.
The interesting thing with hot copper is that many of the "most discussed" stocks (88E and FAR being examples) were massive money makers for people on the site over the last year or so that I've been watching the forums. As I said before, HC doesn't make the market, but certainly where there's smoke there can be fire.
88E headed for another nice open in anticipation of short term news. It needs to be very good news or I think we will see a drop from the substantial build up, even if the news is positive.
22 minutes ago, UNR33L said:
Still thanking my dad for buying me commonwealth bank shares 16 years ago with some inheritance, I made a whole $60 out of that one ;)
your dad should have bought breast implants with inheritance. that what everyone else seems to do with it.
  • Like 1
40 minutes ago, Leroy Peterson said:
good day for 88E. birds must be hitting that refresh button constantly.
I ain't daytrading it...you can set price change alerts with the commsec app :)
Price increases are great, don't get me wrong
But as a long termer they are annoying temptations to sell and take profit, and also a reflection of potential over-anticipation from holders...do not want on the cusp of potentially good long term news.
  • Like 1
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
