Not that accurate...
I got tuned at 230kw (Safe tune due to an issue with the wastegate), then goes to RTR and makes 203kw on its first run 2 weeks later (same boost curve, cooler day)
At the end of the day, I learnt to ignore the numbers. If its making 300kw and doesn't have anything in the midrange, you'd be better off with 260kw of usable power.
  • Like 1
30 minutes ago, joeyjoejoejuniorshabadoo said:
Dissatisfied cause they couldn't afford the petrol to drive home from racepace
racepace is f**king cheap for the service you get.
i dont think theres any other shop that lets the apprentice suck your dick while you wait.
thanks borci, more cock for you tonight birthday boy
  • Like 1
What part of that makes RTR the more accurate one?
wondering why there is like 30 video files on my work phone... iphone "live" photos defaults to on. has to be one of the dumbest f**king phone features ive ever heard. retarded pricks.
  • Like 1
Comparing dynos is ultimately a pointless exercise and the fixation on achieving certain figures is dumb
So too is a ton of power if you're not making it grip or having it anywhere you're actually going to use it
I'd rather use the Birds measure of power - rolling drag races baby
inb4 new 33R has less power than the coveted 23.GTR
  • Like 1
lmfao
set of -5s with GTX cores have popped up... with RP equal length front pipe, basically a full kit
i know i want a single but twin GTX through a RP front pipe is hnnngggggggggggg
No it's not. You've worked on the twins properly now, and now you have a 25 stag. Sif it's not worth going single. And none of this "cops will ream me". You from Thomo. In a 4-door 32. Probably with your cousins in the car. Single turbo is the least of your worries. Just tell them you put 26 can covers on your 25. Done.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
